Running Tcl Script Before Router Reads startup-config
rais
Level 7
Level 7
Is it possible to execute a script on a router that could run before router starts to read startup-config.
Thanks.
not sure if that is possible. You can register and run a TCL script upon reboot:
::cisco::eem::event_register_timer cron cron_entry @Reboot
What exactly are you trying to accomplish ?
Where do I have to save this statement?
Trying to configure an ethernet interface + enable ssh/telnet after 'write erase' reboot on a remote device.
Thanks.
the line is put at the top of the actual tcl script. Let's say your tcl script is called ssh_telnet.tcl. The first line would be:
followed by the actual script you have configured.
On your router, you would configure the below:
event manager directory user policy flash:
event manager policy ssh_telnet.tcl authorization bypass
Edit: you need to save the tcl script to flash:
