Access DMZ systems from either default gateways
ktravis02
Visitor
Hi, I have two routers set up with HSRP connected to two ISPs, one cable and one DSL, so customers can always access our DMZ should one ISP go down. The routers are connected to our trusted network, VLAN1, and our DMZ, VLAN4.
But trusted network PCs going out the default gateway of the Cable Router, can’t connect to the DMZ servers with a default gateway of DSL router, or vice-a-versa . I would like to find a solution for this, so I can balance network load between the two ISPs. I think that we might be able to do this with source routing or route maps. Do you have any ideas?
6 Replies 6
Georg Pauwen
post a drawing of your topology. Policy based routing could work, post the running configs of both routers as well so we can help with the details...
Hello
With the topology you have highlighted I would expect the routing between vlan 1 and vlan 4 users will be done via the L3 switch that interconnects to two rtrs facing your ISP’s
Is this correct if so can you post the configuration of the L3 switch?
Kind Regards
Paul
ktravis02
Visitor
Hello
Looks like you will need to route leak on the two rtrs to allow inter vrf comunication.
Are you using any dynamic routing on those two rtrs - if possiblle post the configuration of those two rtrs please
Kind Regards
Paul
Hi Paul, The only routing protocol I have running on these routers is BGP, for a IPSEC GRE VPN tunnel.
-Ken
Hi Guys, for simplicity, posting just what might  be applicable. Let me know if I am missing anything, or you want config from other router - configured pretty much the same:
version 16.9
no service pad
no service dhcp
hostname Sparklight
boot-start-marker
boot system bootflash:isr4300-universalk9.16.09.04.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no ip source-route
track 10 ip sla 10 reachability
no cdp run
class-map type inspect match-all Inside-DMZ-Class
 match access-group name Inside-DMZ
class-map type inspect match-all Outside-Inside-Class
 match access-group name Outside-Inside
class-map type inspect match-all Outside-DMZ-Class
 match access-group name Outside-DMZ
class-map type inspect match-any All-Protocols-Class
 match protocol tcp
 match protocol udp
 match protocol icmp
policy-map type inspect Outside-Inside-Policy
 class type inspect Outside-Inside-Class
  inspect
 class class-default
  drop
policy-map type inspect All-Protocols-Policy
 class type inspect All-Protocols-Class
  inspect
 class class-default
  drop
policy-map type inspect Outside-DMZ-Policy
 class type inspect Outside-DMZ-Class
  inspect
 class class-default
  drop log
policy-map type inspect Inside-DMZ-Policy
 class type inspect Inside-DMZ-Class
  inspect
 class class-default
  drop
zone security DMZ
zone security Inside
zone security Outside
zone security Snort
zone-pair security DMZ-Inside source DMZ destination Inside
 service-policy type inspect All-Protocols-Policy
zone-pair security DMZ-Outside source DMZ destination Outside
zone-pair security Inside-DMZ source Inside destination DMZ
 service-policy type inspect Inside-DMZ-Policy
zone-pair security Inside-Outside source Inside destination Outside
interface GigabitEthernet0/0/0
 no ip address
 ip nat inside
 zone-member security Inside
 negotiation auto
 spanning-tree portfast disable
zone-pair security Outside-DMZ source Outside destination DMZ
 service-policy type inspect Outside-DMZ-Policy
zone-pair security Outside-Inside source Outside destination Inside
 service-policy type inspect Outside-Inside-Policy
zone-pair security Snort-Outside source Snort destination Outside
interface GigabitEthernet0/0/0.1
 encapsulation dot1Q 1 native
 ip address 10.0.0.1 255.255.0.0
 ip nat inside
interface GigabitEthernet0/0/0.4
 encapsulation dot1Q 4
 ip address 172.17.0.2 255.255.0.0
 ip nat inside
 zone-member security DMZ
 standby version 2
 standby 1 ip 172.17.0.20
 standby 1 preempt
 standby 1 track 10 decrement 10
interface GigabitEthernet0/0/1
 ip flow monitor FlowMonitor input
 ip flow monitor FlowMonitor output
 ip address 24.116.74.210 255.255.255.240
 ip nat outside
 zone-member security Outside
 negotiation auto
ip forward-protocol nd
ip tcp synwait-time 10
no ip http server
ip http access-class ipv4 RouterAccess
ip http authentication local
ip http secure-server
ip http session-idle-timeout 1200
ip tftp source-interface GigabitEthernet0/0/0.1
ip nat inside source static x
xxx
xxx
ip route 0.0.0.0 0.0.0.0 24.116.74.209
ip access-list standard ovrld
 permit 172.17.0.0 0.0.255.255
 permit 10.0.0.0 0.255.255.255
ip access-list extended Inside-DMZ
 permit tcp any any eq www
 permit tcp any any eq 443
ip access-list extended Outside-DMZ
 permit tcp any host 172.17.0.xxx eq 30175
xxx
xxx
ip sla 10
 icmp-echo 8.8.8.8
 frequency 5
ip sla schedule 10 life forever start-time now
