Access Forwarded Port from Another Vlan
mustafa.chapal
I have a Cisco 897VA IOS router. I am unable to access port forwarded of IP in Vlan10 from Vlan20. I am unable to access a SSH port on IP 10.0.0.2 from IP 192.168.0.2.
There is no problem connecting to the SSH port from the same Vlan10 or through the public IP. I want to access the SSH port from Vlan20 using the internal IP instead of the public IP.
Please let me know if I have any issue in the following configuration.
interface GigabitEthernet8
 ip address 99.80.10.233 255.255.255.248
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip nat enable
 ip virtual-reassembly in
 ip verify unicast reverse-path
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.0.0.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat enable
 no autostate
interface Vlan20
 ip address 192.168.0.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat enable
 no autostate
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source static tcp 10.0.0.2 22 interface GigabitEthernet8 22
ip nat source route-map 1 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
ipv6 ioam timestamp
route-map 1 permit 10
 match ip address 1 2
 match interface GigabitEthernet8
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.0.0 0.0.0.255
20 Replies 20
Cristian Matei
   I would say the problem is that you're using domainless NAT (aka "nat enable), thus the "publishing" is out all NAT enable interfaces. Try the following config, it should work, with domain-based NAT (inside/outside domains), and also reconfigure your default-route by specifying a next-hop, otherwise in time you may loose Internet access or router could crash due to insufficient ARP memory:
 no ip nat enable
 ip nat outside
interface Vlan10
 no ip nat enable
 ip nat inside
interface Vlan20
 no ip nat enable
 ip nat inside
no ip nat source static tcp 10.0.0.2 22 interface GigabitEthernet8 22
no ip nat source route-map 1 interface GigabitEthernet8 overload
ip nat inside source static tcp 10.0.0.2 22 interface GigabitEthernet8 22
ip nat inside source route-map 1 interface GigabitEthernet8 overload
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 99.80.10.X
Cristian Matei.
Hi Cristian,
It works according to the configuration you provided but I am looking for a way in which 10.0.0.2 could be SSHd through its own internal IP as well as the public IP from Vlan20.
I need to forward several ports but I am stuck with this.
Please let me know.
Thank you
@mustafa.chapal   Yes, with the provided configuration, for traffic going "outside NAT interface to inside NAT interface" you will be accessing the service based on the public IP, for traffic going "inside NAT interface to inside NAT interface" you will be accessing the service based on the private IP. Test it, it has to work.
Cristian Matei.
Hello
I dont think you need to change the NAT, you just need to amend the nat access-list to deny nat between the two lan subnets.
Example
no access-list 1
ip access-list extended NAT
deny ip 10.0.0.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 192.168.0.0 0.0.0.255 10.0.0.0 0.0.0.255
permit ip 10.0.0.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.0.255  any
no match ip address 1 2
match ip address NAT
Kind Regards
Paul
Hi Paul,
It still did not work using the configuration you provided.
The scenario remained the same.
Thank you
Hello
Just to confirm you used that extended acl with the route-map running NVI nat and you say you cannot establish an internal host -host communication via ssh?
The reason why it works via Domain based nat as suggst by @Cristian Matei  is the original NAT order of preference is performed as however it should work via NVI nat even with its dual route lookup with the above acl applied unless i am missing something fundamental here.
Can you post your configuration as it is now please, also confirm on what you are trying to accomplish, And if that is you wish for a host to be reached via ssh either via its external natted and its internal address.
Kind Regards
Paul
Hi Paul,
Yes thats correct. I used the extended acl with the route-map running NVI nat and I am unable to establish host to host communication via SSH.
I want to reach the host 10.0.0.2 using any IP address within 192.168.0.0/24 in Vlan 20 via SSH through both external natted and its internal IP address.
I want to accomplish the above which works well from a host with an example IP 10.0.0.5 in Vlan 10, it is able to SSH 10.0.0.2 both through the external natted and its internal IP address.
Following is the config.
version 15.7
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service password-recovery
hostname r1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone Chicago
no ip source-route
no ip gratuitous-arps
ip dhcp bootp ignore
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.0.1 10.0.0.100
ip dhcp excluded-address 10.0.0.200 10.0.0.254
ip dhcp pool ccp-pool1
import all
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 8.8.8.8 8.8.4.4 1.1.1.1 1.0.0.1 208.67.222.222 208.67.220.220
ip dhcp pool ccp-pool2
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
no ip bootp server
ip domain name example.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 1.1.1.1
ip name-server 1.0.0.1
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip cef
no ipv6 cef
cts logging verbose
username Example privilege 15 secret
redundancy
no cdp run
ip tcp synwait-time 10
interface Null0
no ip unreachables
interface GigabitEthernet0
switchport trunk native vlan 10
switchport trunk allowed vlan 1,2,10,20,1002-1005
switchport mode trunk
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
switchport access vlan 10
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
ip access-group inside in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
load-interval 30
duplex auto
speed auto
no cdp enable
ntp disable
interface Vlan1
no ip address
shutdown
interface Vlan10
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
no autostate
interface Vlan20
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat enable
no autostate
no ip http server
ip nat source static tcp 10.0.0.2 22 99.80.10.233 2222 extendable
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 99.80.10.233
ip ssh time-out 60
ip ssh version 2
ip access-list extended inside
deny   ip 0.0.0.0 0.255.255.255 any
deny   ip 127.0.0.0 0.255.255.255 any
deny   ip 169.254.0.0 0.0.255.255 any
deny   ip 192.0.2.0 0.0.0.255 any
deny   ip 224.0.0.0 31.255.255.255 any
deny   ip 240.0.0.0 15.255.255.255 any
deny   ip host 255.255.255.255 any
deny   ip host 0.0.0.0 any
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.168.0.0 0.0.255.255 any
deny   udp any any eq ntp
deny   udp any any eq snmp
deny   udp any any eq snmptrap
deny   tcp any any fragments
deny   udp any any fragments
deny   ip any any fragments
permit icmp any any ttl-exceeded
permit icmp any any port-unreachable
permit icmp any any echo-reply
permit icmp any any packet-too-big
deny   icmp any any
permit ip any any
ip access-list extended vty
deny   tcp any any eq 22
permit ip any any
ipv6 ioam timestamp
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner login ^CCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
privilege level 15
no modem enable
transport output ssh
line aux 0
exec-timeout 0 0
no exec
transport output none
line vty 0 4
access-class vty in
privilege level 15
transport input ssh
scheduler allocate 20000 1000
ntp server pool.ntp.org
end
 @paul driver The difference between the two solutions working or not stands in the fundamental difference between the two implementations. For NAT to happen with domain-based NAT (inside,outside), traffic needs to match a NAT statement and flow between NAT domains (inside to outside, or outside to inside), so inside-to-inside to outside-to-outside will not trigger NAT. For NAT to happen with domain less-based NAT (no domains, just NAT enable), traffic needs to match a NAT statement and flow between NAT enabled interfaces (but any NAT enabled interfaces, no more condition).
   He has a problem with its static NVI NAT config. As IOS implements source based NAT and its not a stateful firewall to perform reverse NAT checks (or RPF-NAT check), what happens is that if you initiate the session towards the real IP, the SYN goes untranslated, it reaches the destination, and when SYN-ACK comes to the router, it translates the source (traffic between NAT enabled interfaces and matching NAT statement), thus this is a broken session, will never work.
   With domain-based NAT this is fixed, as he configures its private interfaces in the inside NAT domain, so for traffic flowing between inside or outside interfaces, there is no NAT. Exactly what he wants.
Cristian Matei.
Hello @Cristian Matei
Thanks for the feedback and I do understand but as I have stated mate if the OP confirmed he wants to access a host via external and internal then NVI/ or domain nat I do think there is a possible way incorporating either domain ( depending of ios version) or NVI nat either with some Hari pining
( I’ll probably need to lab it)  - However if it isn’t then as you stated (domain nat) is the correct solution.
Kind Regards
Paul
Hi Cristian,
Please tell me a way how can I SSH 99.80.10.233 from IP 192.168.0.10 in Vlan 20 as outside to inside does not seem to work with the config you provided. I even tried it on a different router.
The actual purpose is to make both inside to inside and outside to inside work using multiple vlans.
Please let me know.
   The below, was your initial statement: "There is no problem connecting to the SSH port from the same Vlan10 or through the public IP. I want to access the SSH port from Vlan20 using the internal IP instead of the public IP."
  With the config i provided you, which works (unless you have some other settings which you have not posted and may affect the functionality), traffic coming inbound on Gi8 (from Internet let's say) should be using the public IP as destination in order to get access, while traffic coming inbound on VLAN 20 should be using the private IP as destination in order to get access. This is what you requested, isn't it?
Cristian Matei.
Hello
So you wish to access internally, other internal hosts via their natted public address if so then youll need to nat hairpin for those internal subnets- please confirm?
Kind Regards
Paul
Hi Paul,
I want to access the natted host via its internal as well as external IP from other VLAN.
For example user 192.168.0.2 in VLAN 20 should be able the access the host through the following ways.
ssh -l root 10.0.0.2
ssh -l root 99.80.10.233 -p2222
@Cristian Matei I apologize for the confusion in my initial question. I meant to say that the user for example 192.168.0.2 in VLAN 20 should be able to SSH the forwarded host via its internal IP 10.0.0.2 as well as the natted public address 99.80.10.233 and port 2222. Also I have provided the complete configuration in my previous message.
Thank you
Hello
Not so sure why you want to access the host via the public natted address and its internal address internally however depending on you ios software i think its applicable.
Below is a possible solution using NVI nat, however depending on you IOS version you myabe  able to do this with domain nat  also.
Example:
no route-map 1
no access-list 1
no access-list 2
int loopback 100
ip address 169.254.1.1 255.255.255.255
ip nat enable
no ip redirects
no ip nat outside
ip nat enable
interface Vlan10
ip redirects
ip nat enable
interface Vlan20
ip redirects
ip nat enable
ip access-list extended NAT-PIN
permit ip 192.168.1.0 0.0.0.255 host 10.0.0.2
ip nat source list NAT interface GigabitEthernet8
ip nat source list NAT-PIN interface loopback 100
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 99.80.10.xxxx
Kind Regards
Paul
