Access Lab from home
Visauk47
Hi All,
I have access to all the latest Cisco switches and I want to access all those switches from home to practice Labs, Is there any way to access all the switches which I left turned on through cloud or something ?
Please let me know.
Vis
julian.bendix
Hi!
Where are your switches located?
In the internal network of a company you work for?
In that case you would need some kind of client-vpn from your home into the companys network of course.
Best regards
Julian
Hi Julian,
Network access is not a problem :)
I just want to know how to access all the switches at once to practice some labs and to do some testing.
V
Hi!
How do you access them usually? I assume over SSH?
If network access is not a problem, you access them the same was as usual then.
Given that SSH access is configured on the Switches.
Best regards
Julian
Hi Julian,
Basically I want to access the switches on cloud where I can configure and test few things and then erase the config, its like a cloud rack which is available to you 24x7, I want to setup a lab like that, but I am not sure how to do it.
At present I have to be in the lab room all the time in order to test things, my office 60-70 m away from the lab room so its not convenient for me to be in the lab all the time.
I dont want to use packet tracer when I have the real equipment's :)
Vis
