Access List Basics - Help!
spacetrance
Community Member
I am having issues locking down a network. I have a SR520 internet facing router.
Requirments:
Network has internal Exchange server with OWA running / DC and internal DNS / RRAS for VPN.
They also are using PPTP services on Windows Server.
They have business line app that runs over ports 15430 and 15431 via a VPN connection.
Need to deny ouside traffic coming into network except for internal intiatied traffic and above items.
I enabled below access list but had to disable it. After enabling below I couldn't resolve dns queries.
List is being applied to WAN interface filtering incoming traffic.
ip access-list extended WAN-FACING-INCOMING
deny tcp any 7x.xx.xx.40 0.0.0.7 eq 3389
permit tcp any 7x.xx.xx.40 0.0.0.7 eq www
permit tcp any 7x.xx.xx.40 0.0.0.7 eq 443
permit tcp any 7x.xx.xx.40 0.0.0.7 eq 1723
permit tcp host 9x.xx.xx.4 host 192.168.2.251 eq 15430
permit tcp host 9x.xx.xx.4 host 192.168.2.251 eq 15431
permit gre any 7x.xx.xx.40 0.0.0.7
permit tcp any 7x.xx.xx.40 0.0.0.7 established
Any suggestions on other ports/ips to open up or access-list order.
9 Replies 9
Edison Ortiz
DNS uses UDP 53 and I don't see that port allowed in the list..
DNS also uses TCP in some cases.
permit tcp any 7x.xx.xx.40 0.0.0.7 eq 53
permit udp any 7x.xx.xx.40 0.0.0.7 eq 53
I did some research and came up with a list of other things that should be blocked to decrease vuneralabilites such as network mapping, DOS attacks and other items.
I created a list from: http://www.sans.org/reading_room/whitepapers/networkdevs/easy-steps-cisco-extended-access-list_231
That includes to following lines:
deny ip 0.0.0.0 0.255.255.255 any
deny ip 10.0.0.0 0.255.255.255 any
deny ip 127.0.0.0 0.255.255.255 any
deny ip 169.254.0.0 0.0.255.255 any
deny ip 172.16.0.0 15.0.255.255 any
deny ip 192.0.2.0 0.0.0.255 any
deny ip 224.0.0.0 15.255.255.255 any
deny ip 240.0.0.0 7.255.255.255 any
deny ip 248.0.0.0 7.255.255.255 any
deny ip 255.255.255.255 0.0.0.0 any
deny tcp any any eq 6669
deny tcp any any eq 2222
deny tcp any any eq 7000
deny tcp any any eq 16959
deny tcp any any eq 27374
deny tcp any any eq 6711
deny tcp any any eq 6712
deny tcp any any eq 6776
deny tcp any any eq 16660
deny tcp any any eq 65000
deny tcp any any eq 27665
deny udp any any eq 31335
deny udp any any eq 27444
deny tcp any any eq 33270
deny tcp any any eq 39168
deny icmp any any echo
Any thoughts?
A 'permit ip any any' should be added at the end.
There are other things you should consider while hardening the IOS device.
A comprehensive list can be found at:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080120f48.shtml
Edison
therefore, i think the combined list wuld be:
! Prevent incoming connetions from non routable networks
! prevent incoming from well known exploits
! Prevent direct RDP and ping maps or floods
deny icmp any any echo-reply
! Allow DNS/OWA/PPTP Connections
! Allow business application connections from specific networks to internal ip and specific ports
! Allow established tcp connentions to come back in
! Allow anyone on outside to come inside
permit ip any any
Since I have to implement this remotely I am obviously cautious that I would break my remote access which runs off of 443/80. Anyone see any other things that have been overlooked???
permit ip any any
The last entry 'permit ip any any' will cover all the permits you've listed above.
The deny icmp any any echo is already implemented, no need to do it twice.
You don't want to disable echo-reply since you want to be able to ping from inside-to-outside.
Ok so by adding the permit ip any any I am essentially opening all incoming ports/ips that were not explicitly denied earlier in the list.
This seems insecure, what I want to do is close all incoming ports except for the ones permitted and established traffic.
I believe you are protecting what needs protection. I'm assuming your internal devices have non-routable addresses and you only NAT what's necessary and mostly use PAT, right?
If you don't add permit ip any any at the end you are going to lock yourself out.
I digress...
Maybe reflexive ACL is what you are really after?
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#reflexacl
spacetrance
Community Member
The server is nat'd 1 to 1 ie static nat so there is a security concern there
