Access list help on router
Andy White
Level 3
Level 3
From the remote VPN side (ASA 10.100.1.66) into the VLAN 10 network (10.104.10.x) on this routers LAN works inbound on ports in the 123 access list, however I need to allow VLAN 10 on this router to go outbound to the the remote ASA VPN (10.100.1.66).  Where do I put the access-list.  For example I need this routers subnet 10.10.4.10.x LAN to get to 10.100.1.66 on destination port TCP/601.  When I try the router shows it's denied, but for some reason it is saying access list 123 is denying it, why as it is an outbound access list into VLAN 10's LAN?
router (10.104.10.x) --EasyVPN-- ASA (10.100.1.66)
denied error:
%SEC-6-IPACCESSLOGP: list 123 denied tcp 10.100.1.66(601) -> 10.104.10.2(6926), 1 packet
Config
interface Cellular0
ip address negotiated
ip access-group 122 in
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 60
dialer in-band
dialer string INTERNET
dialer-group 1
async mode interactive
crypto ipsec client ezvpn toASA
interface Vlan10
ip address 10.104.10.1 255.255.255.240
ip access-group 123 out
ip nat inside
ip tcp adjust-mss 1452
no autostate
crypto ipsec client ezvpn toASA inside
access-list 122 permit icmp host 4.2.2.2 any
access-list 122 permit udp host *.*.*.* any log
access-list 122 deny   ip any any log
access-list 123 permit tcp host 10.100.1.66 any eq 3389 log
access-list 123 permit tcp host 10.100.1.66 any eq 5900 log
access-list 123 permit tcp host 10.100.1.66 any eq 5800 log
access-list 123 permit tcp host 10.100.1.66 any eq 601 log
access-list 123 permit icmp any any
access-list 123 deny   ip any any log
I think I could be getting confused on where I put the outbound access list and why access list 123 should have anything to do with it and deny it.
Please advise as I guess I need to add this somewhere access-list ? permit tcp 10.104.10.0 0.0.0.15 host 10.100.1.66 eq 601
7 Replies 7
ajay chauhan
Level 7
Level 7
This simply mean source 10.104.10.2 is hitting 10.100.1.66 on port 601 where prt 6926 is dynamic source port associated with 10.104.10.2.When return packet comes back in is being denied by ACL 123.
Access-list is applied to right direction but entry should looks somthing like this-
#permit tcp host 10.10.100.66 eq 601 host 10.104.10.2
Think like - Outbound traffic  Source IP    Source Port  Destintion IP Destination Port   (Controlled by ACL IN )
                                          10.104.10.2  6929            10.100.1.66   601
Same reverse way .
Ajay
It is still saying access denied:
%SEC-6-IPACCESSLOGP: list 123 denied tcp 10.100.1.66(601) -> 10.104.10.2(7144), 1 packet
I was on 10.104.10.2(LAN - VLAN 10) and tried to connect to 10.100.1.66 (remote) on tcp 601.
access-list 123 permit tcp host 10.100.1.66 eq 601 10.104.0.0 0.0.0.255 log
What did I do wrong?
10.104.0.0 0.0.0.255 do you know what this is going to cover ?
255 means just the last 8 bits means 10.104.0.1 to 10.104.0.255 .does that cover 10.104.10.2 ?
hope you understand now what wrong you have done
Ajay
What a school boy error, I will never pass my cert with that!
That now works, I'm still a little confused on how it works.  So is the below saying allow 10.100.1.66 on tcp 601 to 10.104.10.x
If so that is the opposite in my mind, as I needed 10.104.10.x to get to 10.100.1.66 on tcp 601.
access-list 123 permit tcp host 10.100.1.66 eq 601 10.104.10.0 0.0.0.255 log
simple it says if 10.100.1.66 is coming with source port should allow for 10.104.10.0 0.0.0.255 for any port.
you need to understand how session works on TCP/IP.
You mentioned:
This is what I applied to vlan 10 outbound
In the access list above isnt 10.100.1.66 and tcp 601 the source ip and port and the destination 10.104.10.x?
Dynamic ports are random you can not guess them.Only thing need to keep in mind direction and source/destination IP  and destination port..
Session means initiator will target well known ports/specific ports for destination IP and will open dynamic port at source.
10.104.10.2 6929>>>>>>>>>>>>>>>>>>>>>>> 10.100.1.66 601   (1st packet)
10.104.10.2 6929<<<<<<<<<<<<<<<<<<<<<<< 10.100.1.66 601   (return packet)
For more information will look how ACL works on cisco.com.
Ajay
