access-list in router
vinoth.kumar
Currently in our network for NAT access we deployed on the 3640 router which some times hang when some spurious traffic generated from LAN or WAN or CPU load
so we are planning to upgrade the NAT Router
for new hardware we need following feature supported
1.NAT with HSRP
2.Hardware capable of handling 300-400 ACL entry
3.CPU performance to handle ACL and NAT
can any one advice me for some cisco router with the feature and also how to avoid the spurious traffic generated from LAN
thanks in advance
Leo Laohoo
870/880, 1800, 2800, 3800 ISR, 1940, 2900, 3900 ISR2
Nagendra Kumar Nainar
Hi Vinoth,
One of the key factor considered while positioning a platform is Volume of traffic (throughput that a platform can handle). Features like NAT, ACL are CPU intensive and requires attention while positioning the platform.
You may have to identify the throughput requirement and features that you will be enabling. Based on this, decide the router by having a look on the router performance chart.
It is advisible to have CPU less than or around 60% with services enabled. This will give you room for unexpected traffic burst without bring down the network.
HTH,
Nagendra
