access list issue and ip route
malai.joseph
Have cisco router 1921 and 3 cisco switch 3560G
i want to configure the cisco router so as network 192.168.4.0/26,192.168.3.0/26,192.168.2.0/26, all to access internet
R1921(config)# ip nat inside source list 102 int G0/0 overload
R1921(config)# access-list 102 permit ip ?
I am i right to do this below?
R1921(config)# ip route 192.168.4.0/26 10.10.10.2
R1921(config)# ip route 192.168.3.0/26 10.10.10.2
R1921(config)# ip route 192.168.2.0/26 10.10.10.2
kindly assist on access-list and ip route?
thanks all
Jo
11 Accepted Solutions
Latchum Naidu
Hi Joseph,
Configure like below inorder to get the LAN access to internet.
First of all you need to configure "ip nat outside" on the wan interface (whcih is connected to your ISP) and "ip nat inside" on your LAN interface like below...
interface GigabitEthernet0/0
ip nat outside
interface GigabitEthernet0/1
ip nat inside
Second default route like below in global config mode...
ip route 0.0.0.0 0.0.0.0 123.49.42.162
Third configure the Global NAT statement like below...
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip access-list extended UNNAT
permit ip 192.168.4.0 0.0.0.63 any
permit ip 192.168.3.0 0.0.0.63 any
permit ip 192.168.2.0 0.0.0.63 any
Please rate the helpfull posts.
Naidu.
Oh...Sorry Joseph, My mistake..
Actually i have not changed the name of the access-list...It is now like below..
ip access-list extended NAT
Naidu.
Hi Joseph,
It seems that you have configured Vlans for the networks 192.168.4.0, 192.168.3.0 and 192.168.2.0 then no need those static routers.
Please click on the correct answer if this answered your question.
Naidu.
Hi Joseph,
It is simple...You need to configure access-lists and applied the access-list under the respective vlan's
Configure the below access lists in the device in which you have configured the Vlans.
192.168.4.0 is a  servers network
192.168.3.0 client network
192.168.2.0client network
interface Vlan10
description Servers network
ip address 192.168.4.1 255.255.255.0
interface Vlan20
description Client1 network
ip address 192.168.3.1 255.255.255.0
ip access-group Client1 in
interface Vlan30
description Client2 network
ip address 192.168.2.1 255.255.255.0
ip access-group Client2 in
ip access-list extended Client1
deny   ip any 192.168.2.0 0.0.0.255
permit ip 192.168.3.0 0.0.0.255 any
ip access-list extended Client2
deny   ip any 192.168.3.0 0.0.0.255
permit ip 192.168.2.0 any
Naidu.
Hi Joseph,
Good question.
We have not defined any rules under the Servers VLAN, so by default all traffic will be permit.
Even if you want explicitly want permit or restrict access then you can configure access-list like below.
ip access-list extended Server
permit ip any 192.168.3.0 0.0.0.255
interface Vlan10
ip access-group Server in
And no problem at all you can ask n number of questions, the idea is that you need to be clear about what you are looking for.
Naidu.
Hi Joseph,
See the below some security tighten from my point of view.
First of all I would suggest connect your router through ssh and never use telnet untill the router not support ssh.
And define access-list like below saying few networks only should able to login to the router so the other network can not login (I think your router is going to connect internet then this is must)
access-list 26 permit 192.168.2.0 0.0.0.255
access-list 26 permit 192.168.3.0 0.0.0.255
access-list 26 deny any any
line vty 0 4
access-class 26 in
login authentication device
transport input telnet ssh
Regarding the logs you want to see like when any one logged into the router the you need to configure the below commands in the router from global
config mode.
archive
log config
  logging enable
  notify syslog contenttype plaintext
  hidekeys
Naidu.
Hi Joseph,
My router is 1921 IOs versio15,i dont know if it support ssh?
I have also have the same router at one of my customer which is managing by me. It will support ssh no doubt about it.
Please use the below commands in global config mode in order to get the ssh enable on the device. Once you enable ssh it wont accept telnet.
Router> enable
Router# config t
Router(config)#
line vty 0 4
access-class 23 in
transport input ssh
how to insert username and password for ssh on router?
Once you set above configure the usernamd and password like below.
Router> enable
Router# config t
Router(config)#
username admin privilege 15 secret 5 ********pwd*********
This you need to use when you connect the device through ssh.
What is this pls transport input telnet ssh?
This will enable the router to accept connections through ssh only.
where logs will be stored and how to check those logs?
Logs will be there on the router buffer. If you want store logs then you need to use any third party syslog server like I am using CiscoWorks for syslog and of course you can use KiwiCat also.
To check the logs on the router.....Use the following command from the exe mode Router#show log ---->This will display the stored logs in the buffer where you can find who logged in and alll.
Hope the above clear and understood.
Naidu.
Hi Joseph,
You need a crypto image to support ssh but you can also verify by doing this command: ip ssh ver in global config and if you want to know if a feature is supported by your IOS/architecture just go on Cisco feature navigator site : http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
If your router supports ssh, in order to use it you must:
1) give a hostname to your router with the global config hostname command
2) configure a domain name with the global config ip domain-name command
3) configure a local user with the global config  username xxx  privilege xx secret xxx  command
The 3rd action answers this question
4) generate a  rsa key with the global config  crypto key generate rsa modulus 1024 command
5) optionaly enable ssh version 2 with the global config ip ssh version 2 command
6) on line vty: login local
how to disable telnet?
7) on line vty: transport input ssh
What is this pls transport input telnet ssh? you mean telnet service will be overwrite by ssh
This means you can telnet  to your vty line and also  ssh to it  with the command in 7) you can only ssh to it
Concerning your ACL the deny any any at the end is useless unless you want to log but then you have to add the  log keyword at the end
why these 2 lines ?
access-list 26 permit 192.168.2.0 0.0.0.63
access-list 26 permit 192.168.3.0 0.0.0.63
For me they are useless as they will never get hit because an ACL is parsed from top to bottom and once a match is done the parsing stops, the 2 first lines will get matched before.
What do you want to log ? the access with ssh to your router? all access or only failed ones?
The config given below your question is for the archive feature not for authentication logging.
You can log in many places but the best is a syslog server( a free one is tftpd32 for windows) and the command is simple:
logging x.x.x.x where x.x.x.x is the ip address or hostname( if you can resolve to ip) of your syslog server
But first verify logging is enabled with the show log command  and if not then enable it with the global config logging on command
then you can use the logging feature on your  final explicit deny with the log keyword or if you have got  a security IOS you can use this  global command: security  authentication failure rate xx log  which will block for 15 sec after xx attempts and log the attempts.
Regards.
Alain.
Hi Joseph,
Now my concern is logs on buffer of a router,am afraid it will consume a lot of memory and cause other problem,is'nt?
Yes, me to agree with you...but if nothing available then the only source is the router buffer to analyze the logs for any critical situations.
CiscoWorks and KiwiCat is an hardware or software ?if software how to conf it on window machine or linux?
I have CiscoWorks and I can teach you each and everything about it but it is license based and costly you need to buy it from CiscoWorks and untill you have a large network say 300-400 devices to manage no need this.
I would suggest you to use KiwiCat tools which is low cost and you can get trail version for 30 days.
See the below details for KiwiCat....
You can download this free tool and pay with this. You can just install it in any windows mechine.
http://kiwisyslog.com/kiwi-cattools-overview/
Naidu.
Joseph,
tftpd32  is a windows program.
As i said above  to send logs to this server just issue logging x.x.x.x where x.x.x.x is IP address of the machine hosting the syslog service.
I haven't tried on a linux box yet.
Regards.
Alain.
Hi Joseph,
Follow the below link will help you.
http://www.hak5.org/forums/index.php?showtopic=13229
Please click on the correct answer on all posts if they answered your question.
Naidu.
20 Replies 20
Latchum Naidu
Hi Joseph,
ip nat outside
ip nat inside
Naidu.
Thanks Naidu
For quickly reply
can i get clear on
why you use word NAT and below introduce word UNNAT?,is it arlight?kindly help am new to cisco on extended access list
How about
does not required ?
Joseph
Naidu.
Thanks naidu,
i convenced this is a true answer..thanks
what about this?
does not required ?i need to know what is this,what it do?
Joseph
Hi Joseph,
Naidu.
Yes Naidu,
I have vlan and network  192.168.4.0 is a  servers network
What need to be done so as
network 192.168.3.0 should not be able to communicate with  192.168.2.0 and viceversa
network 192.168.3.0 and 192.168.2.0 should be able to reach/communicate with 192.168.4.0 and viceversa
thanks for ur support
joseph
Hi Joseph,
interface Vlan10
interface Vlan20
interface Vlan30
Naidu.
thanks Naidu,
interface Vlan10
interface Vlan20
interface Vlan30
//hope this will deny all from client2 and permit all from client1
//hope this will deny all from client1 and permit all from client2
//how about permitting to server to client1 and client2
sorry for asking too much,but you help me a lot
Joseph
Hi Joseph,
Good question.
interface Vlan10
Naidu.
Great job Naidu,
Now i want to have security issue on cisco router1921,what best security implementation can be done?
can i connect to my router with ssh ?and not telnet?what need to be done for this to be on place?
can i have a check of logs that who has try to ssh on my router?how to do that?
thanks very much
joseph
Hi Joseph,
line vty 0 4
access-class 26 in
config mode.
archive
log config
  logging enable
  hidekeys
Naidu.
Thx
My router is 1921 IOs versio15,i dont know if it support ssh?and i accustomed to linux and i know ssh require username and password ,how to insert username and password for ssh on router?and how to disable telnet?
What is this pls transport input telnet ssh? you mean telnet service will be overwrite by ssh?
hope to be this conf on router,that is 192.168.2.0 and 192.168.3.0 network will be able to ssh(you can ssh while u are in this network)
line vty 0 4
access-class 26 in
config mode.
archive
log config
  logging enable
  hidekeys
Joseph
Hi Joseph,
Router> enable
Router# config t
Router(config)#
line vty 0 4
access-class 23 in
transport input ssh
Router> enable
Router# config t
Router(config)#
Naidu.
Hi Naidu,
Thanks,The details is clear and suffice.
CiscoWorks and KiwiCat are Intrusive detective system?can i get to know a,b,c from yours ?and if any?how to make it happens?
I think keeping logs on other place away from router is an ideal...
joseph
