Odd issue - can't ping within LAN
Effortless15
Hi all,
I haven't come across this before and have been scratching my head about it for the last few hours and need a second (or third or fourth!) pair of eyes here.
I have an ASA5510 at the network edge, an inside interface of 10.1.0.x, a dmz interface of 192.168.1.x
                                                  Internet
                                                  ASA
                        DMZ  ------------------|-------------Inside--------------------------------------------------------Private WAN Links
                         Server1---------------------------LAN
Server1 has 2 interface. One outward facing is 192.168.1.2. One internal interface is 10.1.0.2
There is an additional complexity here where there is a managed service (private network, not VPN) on 10.1.0.254 which takes care of traffic from other sites.
LAN clients behind the inside interface of 10.1.0.1 can ping 10.1.0.254. Server1(TMG server) cannot ping 10.1.0.254 at all.
The error I receive is "regular translation creation failed for icmp src inside:10.1.0.254 dst inside:10.1.0.2 (type 0, code 0)"
There is a NAT exempt for 10.1.0.x so unless I am missing something simple I'm dumbfounded.
Happy to provide config where needed.
Edit: I have also tried changing the IP address on Server1 just to make sure there was no NAT rule or ACL that I was missing.
E.
John Blakley
Can you post your global (publics changed) and nat configs, including any acls that are applied?
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John,
Turned out to be a false alarm.
The upstream provider had to reset the router for the private network due to routing changes not taking effect. Considering when they were trying to trace/ping it wasn't even hitting the 5510!
Thanks anyway!
