Access-list not blocking traffic correctly
Thomas Ossman
I apologize if this is the wrong place to be asking this and if this is something easily searched for.  I just got thrown into a Network Administrator position for a small WISP the guy I am replacing did not keep good documentation so I'm dealing with that on top of the fact that I do not have nearly enough experience to be called a Network Admin.
So we have commercial customer who has a few buildings within our service area that we provide a back up Internet connection for as well as private links between their locations, their main Internet feed is provided by Comcast.  We help them manage their Cisco routers when they cannot figure something out, the router in question is a 2821.  They're having a problem with their phone server's web page being accessible from outside their network, the valid IP address for this phone server is one from Comcast.  They had the guy whose position I have been thrown into come out to block that access, he created an access-list on their router and applied it to the interface that Comcast plugs into.  From my limited knowledge about access-lists it looks like it should be working but sure enough when I type in the valid IP of their phone server I am taken right to it's welcome page.  Below I have included the relevant lines from the running-config on the router as well as the relevant output from "show ip access-lists".  Any help would be much appreciated.
From running-config:
interface GigabitEthernet0/1
 description Comcast Internet
 ip address x.x.x.85 255.255.255.248
 ip access-group 104 in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map vpn1
access-list 104 permit udp host 64.136.174.30 eq 5060 host x.x.x.81 eq 5060
access-list 104 permit udp host 64.136.174.31 eq 5060 host x.x.x.81 eq 5060
access-list 104 deny   udp any eq 5060 host x.x.x.81 eq 5060
access-list 104 deny   tcp any eq www host x.x.x.81 eq www
access-list 104 deny   udp any eq 80 host x.x.x.81 eq 80
access-list 104 permit ip any any
Output of show ip access-lists:
Extended IP access list 104
    10 permit udp host 64.136.174.30 eq 5060 host x.x.x.81 eq 5060 (7141 matches)
    20 permit udp host 64.136.174.31 eq 5060 host x.x.x.81 eq 5060 (7101 matches)
    30 deny udp any eq 5060 host x.x.x.81 eq 5060 (466 matches)
    40 deny tcp any eq www host x.x.x.81 eq www
    50 deny udp any eq 80 host x.x.x.81 eq 80
    60 permit ip any any (92626384 matches)
Jon Marshall
is that the line that is meant to block traffic ?
If so it won't work because the source port is never port 80 so it doesn't match and then the traffic matches the "permit ip any any" at the end.
It should read -
access-list 104 deny  tcp any host x.x.x.81 eq www
you need to remove the other line and add that one.
Note you may or may not need to recreate the whole acl, depends on your IOS.
If you just type in the new line it will add it after last line and so it will never be matched so you need to make sure it is inserted before that line.
If you do have to recreate the acl make sure you have the last line there or you will cut off all internet traffic.
Jon
Jon Marshall
It should read -
Jon
I believe it was the line meant to block traffic.  I was able to insert the line access-list 104 deny tcp any host x.x.x.81 eq www and remove the other and now I cannot get to the phone server's welcome page.  Thank you very much for your help, what you said makes perfect sense and I should have caught that myself.
