Access list option
omyma1234
hi ,
we have bought a new router 2800 series and i tried to apply access-list command
(config)# access-list 110 deny ip host X.x.x.x host y.y.y.y eq telnet
i have received an error message as the command is unrecognized , when i used help option i found that (eq -gt -...) not found and they replaced by:
dscp - fragments -log - log-input
precedence - time-range - tos
could you please tell me ,how to use the command to prevent specific port?
yours omy
vladrac-ccna
Level 5
Level 5
Hello friend
just change "IP" to TCP and you are good to go
(config)# access-list 110 deny tcp host X.x.x.x host y.y.y.y eq telnet
check a better way to configure ACL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/ch05/hipaclis.htm
Vlad
