Access List Question
chueymtz
I want to separate my network, i have 2 vlans 10.76.0.0 and 172.16.0.0, I don't want them to be able to ping or communicate with each other. I am currently able to ping ex: computer 10.76.2.30 can ping 172.16.32.1, we need to separate them and not allow them to talk at all. This is the access list I currently have configured
ip access-list standard 50
10 permit 192.168.0.0 0.0.255.255
20 permit 10.76.0.0 0.0.0.255
30 permit 10.233.4.0 0.0.1.255
40 permit 10.243.4.0 0.0.1.255
ip access-list extended 101
10 deny ip any 172.16.0.0 0.0.255.255
20 permit ip any any
and here is show ver on the switch
Cisco IOS XE Software, Version 16.12.03a
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Versi on 16.12.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 28-Apr-20 09:37 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.2r, RELEASE SOFTWARE (P)
HQ_9300 uptime is 1 year, 1 week, 4 days, 16 hours, 29 minutes
Uptime for this control processor is 1 year, 1 week, 4 days, 16 hours, 30 minute s
System returned to ROM by PowerOn at 12:53:02 UTC Mon Aug 17 2020
System image file is "flash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: REGISTERED/AUTHORIZED
cisco C9300-48P (X86) processor with 1343703K/6147K bytes of memory.
Processor board ID FJC2428T0DK
3 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2 TwentyFive Gigabit Ethernet interfaces
2 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address :
Motherboard Assembly Number : 73-18274-05
Motherboard Serial Number :
Model Revision Number : A0
Motherboard Revision Number : A0
Model Number : C9300-48P
System Serial Number :
Switch Ports Model SW Version SW Image Mode
* 1 65 C9300-48P 16.12.3a CAT9K_IOSXE INSTALL
Configuration register is 0x102
It's not working because the subnet is 10.76.2.0/24 and not 10.76.0.0 as you originally said.
In the acls I provided in last post change  -
10.76.0.0 0.0.0.255 to 10.76.2.0 0.0.0.255
and try again.
Jon
11 Replies 11
under SVI VLAN 172.76.0.0
ip access-group 101 in
10 deny ip  172.16.0.0 0.0.255.255 any
I added that and it can still ping
ping 10.76.2.30 srouce 172.16.32.1
are this ping success ?
Yes i can ping from 172.16.32.1 to 10.76.2.30 and vice versa
I don't know what acl 50 is meant to be doing but for your requirement -
10 deny ip 172.16.0.0 0.0.255.255 10.76.0.0 0.0.0.255
apply the above acl inbound to the L3 interface for 172.16.0.x
ip access-list extended 102
10 deny ip 10.76.0.0 0.0.0.255 172.16.0.0 0.0.255.255
apply the above acl inbound to the L3 interface for 10.76.x.x
Jon
That didn't fix it, I can still ping both ways
and try again.
Jon
That worked thanks
can I see
show ip access-list?
Are the default GW for PC is SVI IP address ?
172.72.0.0/24 different than 172.72.2.0/24
that why ?
SVI of VLAN must same as IP destination in your ACL.
also from
show ip ACL
you see match with permit any any meaning there is wrong in subnet/mask
