Access-list with Negate.. how can be done!
Beacon Bits
Hi Guys,
I need to match the source traffic from 10.100.100.* to a destination other than 10.0.0.0/8.
Which wildcard mask do I need to apply that will only check other than 10.*.*.*.* (the first octet has to be 10)
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 x.x.x.x.
Please help ??
Hello
ip access-list extended ACL permit/deny
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.255.255.255  10.0.0.0/8
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.255.255  10.0.0.0/16
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.0.255  -  10.0.0.0/24
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.1.255  -  10.0.0.0/23    255-254 =1
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.3.255  -  10.0.0.0/22    255-252 =3
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.7.255-    10.0.0.0/21    255-248 =7
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.15.255-  10.0.0.0/20    255-240 =15
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.31.255-  10.0.0.0/19    255-224 =31
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.63.255-  10.0.0.0/18    255-192 =63
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 10.0.0.0 0.0.127.255- 10.0.0.0/17   255-128 =127
etc..
Kind Regards
Paul
Seb Rupik
Hi there,
If you are using the ACL for pattern matching, then why not use a deny to not match (negate) traffic destined to 10.0.0.0/8 then match everything else:
ip access-list extended ACL deny ip 10.100.100.0 0.0.0.255 10.0.0.0 0.255.255.255
ip access-list extended ACL permit ip 10.100.100.0 0.0.0.255 any
cheers,
Seb.
