Access lists - sanity check?
darren.g
Level 5
Level 5
I'm embarrassed to have to ask this, but it's been so long since I have actually had to write an access list, I'm doubting myself.
I have a 800 series router running IOS 12.4 which is used by a small business I occasionally do work for. The business has a /24 of live (non RFC1918) IPv4 addresses inside it which is used for numerous devices, which is delivered via ethernet from an ISP NTU.
Most of them are secure enough that I don't worry about them, but they've just added a VoIP phone gateway which is completely insecure - beyond a password on the management interface - and even that is HTTP only (not even HTTPS).
I want to put an access restriction on the interface which plugs into the ISP NTU to block everything except the authorised SIP host from connecting to the gateway - I know it's not perfect, but it's better than what is there now - while not interrupting access to any other devices.
I've so far got this (Interface F4 is the incoming link from the ISP NTU)
access-list 101 remark Blocks anything but SIP to Phone gateway
access-list 101 permit ip host XXX.XXX.XXX.XXX host YYY.YYY.YYY.YYY
access-list 101 deny ip any host YYY.YYY.YYY.YYY
access-list 101 permit ip any any
interface F4
ip access-group 101 in
Will this permit only conenctions from XXX.XXX.XXX.XXX to the internal host YYY.YYY.YYY.YYY, and allow unfettered access to any other IP address on the inside? Or have I missed something?
Thanks.
Your access-list is correct.
it permits host XX to access host YY
It denies others to access YY
It permits every other access to your other hosts.
interface F4
It controls traffic comming from ISP to your network.
Masoud
5 Replies 5
interface F4
Masoud
darren.g
Level 5
Level 5
Thank you Sir. Appreciate the response, and glad my memory isn't as bad as I thought it was!
You are very welcome. You can also be more strict.
access-list 101 permit udp host XX host YY eq 5060
access-list 101 permit udp host XX host YY eq 5061
access-list 101 deny ip any host YYY.YYY.YYY.YYY log [in case of facing problem in connection]
Please check the link below. It thought it might be helpful.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_protocol_cbac_fw/configuration/12-4t/sec-prot-cbac-fw-12-4t-book/sec-prot-fw-sup-sip.html
Masoud
Don't really need to be stricter - but for some reason, this is not triggering on thaffic to the specific host concerned, and I can't figure out why.
show access-lists
Extended IP access list 101
    10 permit ip host XXX.XXX.XXX.XXX host YYY.YYY.YYY.YYY
    20 deny ip any host YYY.YYY.YYY.YYY
    30 permit ip any any (58 matches)
the access list is plainly being processed (the matches on the third statement show that), yet I can still access the restricted IP address from a non-permitted host.
Can you shed any light?
Edit : No matter. Made it work. Applied it to the wrong interface by mistake. Doh! Thanks again!
I was confused utill I saw your last sentense. Is it working now?
Masoud
