Access lists
rasoftware
Do I need to add deny any any at the bottom of my ACLs? I thought by default an implied "deny" existed at the end. I only ask because using SDM it adds it.
pkhatri
Level 11
Level 11
No, you do not need it as it is implied.
The use of it by SDM is purely for the sake of readability....
Hope that helps - pls rate posts that help.
Paresh
pkhatri
Level 11
Level 11
Paresh
