queue-limit and hw-buffer
rabeder
hi,
my question:
i have a router with a serial frame-relay link.
on this link i enabled cbwfq - gold,silver queue.
i saw a lot of drops in the gold-queue, so i tuned the gold-queue with the "queue-limit" command - and now it is ok.
my question is a general on:
is there a relationship between the "queue-buffer" and the "hardware-buffer" from the interface.
in my understanding it is necessary to increase the hw-buffer (tx-ring) if i increase the softwarebuffer in the queues - right.
i did a lot of search on cco but i did not find the right paper.
is anyone out there who has a technical describtion of this relationship??
thanks a lot and greetings from austria
pkhatri
Level 11
Level 11
Greetings from Australia to you !
The "queue-limit" command configures the size of the software queue. The "tx-ring-limit" command configures the size of the hardware queue.
When using a fancy queueing mechanism like CBWFQ on an interface, IOS will automatically set the tx-ring size to a smaller value. You can tune this further using the tx-ring-limit command. In general, when using software queueing, you want the tx-ring size to be as small as possible (while being large enough to drive the interface to full capacity).
So the answer to your question is: NO, you do not need to increase the hw-queue size when increasing the software queue-limit.
Hope that helps - pls rate posts that help.
Paresh
lgijssel
Level 9
Level 9
Don't know if you knew this one already:
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080103eae.shtml
I hope it comes close to what you are looking for.
Leo
