Access point not joining wireless lan controller
tirabor01
I have been trying to troubleshoot a 2125 WLC  to join a 1252 access point but it has not been successful.
The access point lights keep blinking.
Please do see logs below:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 5.2.193.0
RTOS Version..................................... 5.2.193.0
Bootloader Version............................... 4.0.191.0
Emergency Image Version.......................... 6.0.199.4
Build Type....................................... DATA + WPS
System Name...................................... Cisco_f4:f7:c0
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.828
IP Address....................................... 192.168.1.5
System Up Time................................... 6 days 2 hrs 42 mins 39 secs
System Timezone Location.........................
Current Boot License Level.......................
Next Boot License Level..........................
Configured Country............................... SI  - Slovenia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
--More-- or (q)uit
Internal Temperature............................. +49 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
Burned-in MAC Address............................ C8:4C:75:F4:F7:C0
(Cisco Controller) >show network summary
RF-Network Name............................. law school
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Mode..................... Disable
Ethernet Broadcast Mode..................... Disable
AP Multicast Mode........................... Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Enable
Mgmt Via Dynamic Interface.................. Enable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
The access point software image is the same as the wireless lan controller software image.
What could be the issue?
Jon Marshall
You would get help a lot more quickly if you posted this into the Wireless forums where there are people who should be able to help you out.
Edit - you should be able to move this post there rather than reposting.
Jon
