Can I stop someone downloading a huge file if I kow the source/destionation IP?
Andy White
Level 3
Level 3
I noticed that a user was downloading a huge file today and it was using most of our internet bandwith,  I noticed it via Netflow.
If I know the source and destination IP can I use the ASA to drop the traffic?
Andy,
So for you the command would be:
hostname(config)# access-list Name extended deny any destination-ip
hostname(config)# access-list Name extended permit ip any any
Then apply it going out on your interface
Here is a link in case you need it
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/acl_extended.html
7 Replies 7
Jay Vivas
Andy,
Do you have a router onsite that you can set an ACL on blocking all traffic going to the destination IP?
No, the routers on the outside of the ASA are manage by our ISP.
Was hoping the ASA could help.
Andy,
The ASA is not my best subject but I'm pretty sure ACLs work the same from the CLI of the ASA as they would in a Cisco router.
Andy,
It's a 50MB line, I might add QoS so http/https on use 30mbps of it.
add it to the inside and outside interface
Jon Marshall
Yes if you know the ports just don't allow them between those IPs.
Or for a more drastic solution you could just block all IP between those two IP addresses.
edited - rant over :-)
Jon
Jay Vivas
Andy,
Were you able to apply the ACL to your ASA?
