Access Point Question
msisko527
hello,
          I have a Cisco Aironet 1240AG Access Point and I am trying to set up a guest network that is secure and limited in bandwidth utilization. I see an option under security > SSID Manager on the web interface to select an interface of Radio0-802.11G, Radio1-802.11A or both. Can I put the guest network on the Radio1-802.11A and make it more secure/bandwidth limited or does this option not matter? Has anyone had any experience with setting up a guest network on a AP like this?
Michael
John Blakley
I've not had experience with the web management piece. Is this access point controlled by a WLC or is it configured on the access point directly? Generally, you cannot run multiple SSIDs on the same vlan. You'll need to create a vlan for each ssid that you want. You can do this through the gui, but I wouldn't be able to help you with that. The cli is configured in the following manner:
dot11 sside PrimaryNetwork
   vlan 1
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7
dot11 ssid GuestNetwork
  vlan 2
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7
int d0
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid PrimaryNetwork
ssid GuestNetwork
mbssid
int d0.1
encapsulation dot1q 1 native
bridge-group 1
int d0.2
encapsulation dot1q 2
bridge-group 2
int f0.1
bridge-group 1
int d0.2
bridge-group 2
int bvi1
You'd trunk the port that the AP connects to and allow vlans 1 and 2 over the trunk. Then you would configure a router or L3 switch to route for this vlan.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7
  vlan 2
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7
int d0
ssid PrimaryNetwork
ssid GuestNetwork
mbssid
int d0.1
bridge-group 1
int d0.2
bridge-group 2
int f0.1
bridge-group 1
int d0.2
bridge-group 2
int bvi1
HTH,
John
Hi John,
This would be configured on the access point directly. I don't have a WLC.
So only using VLAN's will allow me to adjust bandwidth for a second SSID? For security reasons does anyone put a guest network (second network) on the same AP?
Sure...I have them in our company. You control with firewall acls, wireless acls, etc. on where the user can go. I'm sure it depends on what sector you're working in if it's seen as an extreme security risk though. Technically, real secure companies won't have wireless access at all. You would only be able to use separate vlans to support more than one ssid. If you try to put a second ssid in the same vlan, it will tell you that it's not able to do it.
From here:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37ssid.html
Step 5
vlan vlan-id
(Optional) Assign the SSID to a VLAN on your network. Client devices  that associate using the SSID are grouped into this VLAN. You can assign  only one SSID to a VLAN.
HTH,
John
