02-11-2006 04:55 AM - edited 03-03-2019 11:43 AM
Hello friends,
Can you please let me know the major diference between Prefix list, Access List & Distribute list.
Or any good technichal documentation for the same.
MAX
02-11-2006 05:08 AM
Hi Max,
A prefix-list is used primarily to match on routes that are being advertised by routing protocols.
An access-list is used for a number of things including:
- filtering actual traffic entering/leaving an interface
- filtering routes being advertised by routing protocols. The preferred way to do this nowadays is using prefix-lists
A distribute-list is used solely for filtering routes being advertised by routing protocols. Unlike access-lists and prefix-lists, which provide the matching criteria for routes, the distribute-list is just a mechanism to use an access-list or a prefix-list for received/advertised routes. That is, a distribute-list cannot exist in isolation - it has to use an access-list or a prefix-list to match the routes it is letting through.
Hope that helps - pls rate the post if it does.
Paresh
02-21-2006 06:59 AM
Hi max,
One of the main Prefix list options that it's faster than ACL & Distribute list due to it's lines fashon, you can permit or deny any number or subnets with one line which is very Sclabile.
Hope that help
Best Regards,
Mounir Mohamed
