Access restrict
jopetik09
Level 3
Level 3
Hi All,
In my network we have three 3 VLANS set up on my 3560G switch.
Can anyone tell me how I can allow pcs on VLANS 1 and 3 access to VLAN 2 but should not to others
And VLAN 1 should not to get to VLAN 3 or VLAN 3 should not get to VLAN 1.
Jopeti.
3 Accepted Solutions
Latchum Naidu
Jopeti
This is not much clear but of course you can try like below... I am just assuming Vlan address, you can take your real address...
vlan 1 = 10.10.10.0/24
vlan 3 = 10.10.12.0/24
access-list stop_vlan1 extended
deny ip 10.10.10.0 0.0.0.255 10.10.12.0 0.0.0.255
permit ip any any
access-list stop_3 extended
deny ip 10.10.12.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip any any
Interface vlan 1
ip access-group stop_3 in
Interface vlan 3
ip access-group stop_vlan1 in
Please rate the helped posts...
Naidu.
No problem...
Is there any switch ports configured under this vlan or not?
Because untill you associate any ports to that vlan it wont come up...
Please rate all the helped posts...
Naidu.
Jopeti,
Log into your switch and go to any interface which you want to access respectively
Give commands like below
Switch# int gi4/39
switch port access vlan 2
switch port mode access
Then see the status, it should up up now...
Naidu.
7 Replies 7
Latchum Naidu
Jopeti
permit ip any any
permit ip any any
Interface vlan 1
Interface vlan 3
Naidu.
I am sorry for that not clear But your suggestion seems OK.
But when i give the following command #sh ip int brief
I found that Vlan 2 is down down...What could be the problem
Jopeti
No problem...
Naidu.
OK, what should i do to associate the ports...
Jopeti.
Jopeti,
Switch# int gi4/39
Naidu.
Thansk....It is cleare and working now
Jopeti.
To associate VLAN2 to port f0/3:
interface f0/3
switchport mode access
switchport access vlan 2
Regards.
Alain.
