Access RomMon using USB connection
joewalvoxbright
                   I have a 1921 router.  Using usb cable I can connect to the console but cannot get the router into rommon mode.  I saw a post for a 1941 router where you can remove the flash to get it into rommon mode, but the 1921 flash cannot be removed.  I am using Mac terminal and screen command but am not able to send break signal.  would love to know if its possilble.
According to this link, the flash on a 1921 is on a daughter-board:
http://hope.mx/break-sequence-on-a-cisco1921
Leo Laohoo
I think you can.  The CF is "hidden" behind a dust cover.  The slots are located at the BACK of the unit, to the left.  The back is where the ports and EHWIC slots are.
Had a close look.  Yes.  1921 flash is internal.
