EIGRP commands not showing up in WAN router config??
Steve Coady
Hello
I have this instance configured
router eigrp 10
network 10.44.x.101 0.0.0.0
I have added no auto-summary and a couple redistribute commands but they do not show up in config.
What am I doing wrong?
sMc
daniel.dib
Level 7
Level 7
Did the entire EIGRP config go away or just those lines of config? Depending on your IOS version no auto-summary might be the default and then it wouldn't show up in the config. Your redistribute statements should be there though.
If the entire config went away it's possible that you didn't have EIGRP active on any interfaces but that should not be the case if you put a network statement. Can you post the config?
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
daniel.dib
Level 7
Level 7
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Daniel
Thank you for the reply.
The IOS has it as the default. We are good to go
sMc
