Accessing file shares behind router using NAT
JOSE TORRES
I am trying to access a file share behind a router where I am using NAT.
I have created a static 1 to 1 translation for the outside to the inside address so all other traffic like RDP (Terminal Services) works fine but I cannot get a file share like \\172.16.1.3\share to connect from the outside to the inside.
Any tips or assistance would be greatly appreciated.
Thank You,
BTW I am using an 806 with 12.2 code, not sure if the router capabilities would be an issue.
IOS (tm) C806 Software (C806-OY6-M), Version 12.2(2)XK2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 16-Feb-02 16:25 by ealyon
Image text-base: 0x80013170, data-base: 0x8053CFD0
ROM: System Bootstrap, Version 12.2(1r)XE2, RELEASE SOFTWARE (fc1)
ROM: C806 Software (C806-OY6-M), Version 12.2(2)XK2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 57 minutes
System returned to ROM by reload
System image file is "flash:c806-oy6-mz.122-2.XK2.bin"
CISCO C806 (MPC855T) processor (revision 0x301) with 30720K/2048K bytes of memory.
Processor board ID JAD060406VQ (197933467), with hardware revision 0000
CPU rev number 5
Bridging software.
2 Ethernet/IEEE 802.3 interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
bstremp
Level 2
Level 2
jitesh1982
Hi joes .
u r translating network address. private to private or private to public .
if ur translating pvt to public
after doing static nat. connect using public ip from outside .or just try to telnet that outside ip address from outside using rdp port . port number 3389
for example if ur outside ip is a.b.c.d then
telnet a.b.c.d 3389 . from outside ,try this and let me know
