Can't get telnet session to ADSL router
bradlesliect
837 ADSL Router - Basic Config, no access-list
line vty 0 4
exec-timeout 0 0
password 7 <snip>
login local
transport preferred telnet
transport input telnet ssh
transport output none
what's missing?
12 Replies 12
icabrera
Level 4
Level 4
Hi, try:
no login local
login
this is because with "login local" it's going to look at the local databasean d it's not going to use the password you set under teh line vty, so put only "login".
Hope this helps, if so pls rate post
removed.....still not working ;(
the telnet just hangs on
Trying XXX.XXX.XXX.XXX...
after a while i get this :
telnet: Unable to connect to remote host: Connection timed out
there is no connection refused or anything?
Hi, ping is working?
there is no problem with ping. it works fine. the other problem is that i cannot config dyndns.
i will try to upgrade the IOS. should this fix the prob? The router has the dfault IOS it was shipped with. Will upgrade to latest advIP IOS but will it fix prob?
Hi, why don't you try with the simpliest config first to see that telnet is working and after you can add more commands.
Try:
line vty 0 4
exec-timeout 0 0
login
password xxxx
gokula_chandran
First try the basic commands as below....
line vty 0 4
exec-timeout 0 0
password 7
login local
This is not working! What am I doing wrong? This should be simple. What am I missing?
version 12.3
no service pad
service password-encryption
hostname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
logging console errors
clock timezone utc 2
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.10.10.1
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no crypto isakmp enable
interface Ethernet0
ip address 192.168.0.1 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1348
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username password
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 10 permit
access-list 20 permit
access-list 23 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
control-plane
line con 0
exec-timeout 120 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
exec-timeout 0 0
password
login
scheduler max-task-time 5000
end
Hi ,
Everything looks fine . Just a basic check , Your sessions are not full in your router right . Because you have given " exec-timeout 0 0 " , earlier telnet sessions might not have timed-out.
Can u check " sh users " and look out any sessions. If present do a "clear line vty *"
Hope this helps
regards
vanesh k
nope.... no other sessions except a console session. Cannot be that?
when i connect my notebook to the port on the router and get DHCP address, I am able to telnet to the router ehternet IP as well as the ADSL IP.
If I try from my office LAN I can't telnet to the ADSL IP Address.
Is there any IP conflict between your LAN IP and ADSL IP.
Senthil
