Accessing My Cisco lab from outside (from the internet)
Hi ,
Does anyone have an idea about , how can I access my Cisco router from the internet . I can telnet from inside but I can't from outside.
I can ping the router from outside but I can't access it using telnet.
5 Replies 5
Julio E. Moisa
If you are using a public IP you could create a static NAT to translate the private IP to the Public IP and using specific ports like ssh or telnet.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I already did , but still does not work .
is possible to see your config? and if you have a diagram?
ip dhcp pool testpool
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 4.2.2.2
ip domain name test
interface FastEthernet0/0
description INTERFACE CONNECTED TO INTERNET
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
password test
login
rotary 33
transport input ssh
line vty 5 10
password test
login
rotary 33
transport input ssh
line vty 11 100
login
scheduler allocate 20000 1000
end
Try to configure something like this static NAT:
ip nat inside source static tcp <private IP> 22 <Public IP> 22
