09-08-2005 12:23 PM - edited 03-03-2019 10:27 AM
I recently setup Cisco VPN access for some of our remote users. While the users are VPN in they are not able to access resources using the UNC name. The ip address works just not the UNC name. I think it is something in my ACL. Can someone offer any suggestions to what I might be missing. Below is current config:
resource policy
ip subnet-zero
ip cef
ip inspect name fw ftp timeout 3600
ip inspect name fw h323 timeout 3600
ip inspect name fw http java-list 3 timeout 3600
ip inspect name fw rcmd timeout 3600
ip inspect name fw realaudio timeout 3600
ip inspect name fw tcp timeout 3600
ip inspect name fw tftp timeout 30
ip inspect name fw udp timeout 15
ip inspect name fw vdolive timeout 3600
ip inspect name fw streamworks timeout 3600
ip inspect name fw sqlnet timeout 3600
ip inspect name fw dns timeout 3600
ip inspect name fw pop3 timeout 3600
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
ip domain name indydomain.local
ip name-server 10.1.35.52
ip name-server 10.1.34.55
interface Loopback0
ip address 192.168.34.1 255.255.255.0
interface FastEthernet0/0
description connected to 10.1.34.0
ip address 10.1.34.2 255.255.255.0
ip helper-address 10.1.35.52
ip helper-address 10.1.34.55
no ip redirects
ip nat inside
no ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Serial0/0/0
description PTP to Greenwood
ip address 10.0.0.2 255.255.255.248
ip nat inside
service-module t1 clock source internal
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
interface Serial0/1/0
description PTP to Internet
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip access-group 100 in
ip inspect fw out
ip nat outside
ip route-cache flow
crypto map rtp
router rip
version 2
network 10.0.0.0
no auto-summary
ip local pool VPNPool 172.16.0.1 172.16.0.254
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 XXX.114.64.209
ip route 10.1.35.0 255.255.255.0 10.0.0.3
ip nat inside source route-map nonat interface Serial0/1/0 overload
ip nat inside source static 10.1.34.59 xxx.114.118.1
ip nat inside source static 10.1.34.156 xxx.114.118.2
ip nat inside source static 10.1.35.56 xxx.114.118.3
ip nat inside source static 10.1.35.253 xxx.114.118.4
ip nat inside source static 10.1.34.55 xxx.114.118.5
ip nat inside source static 10.1.35.52 xxx.114.118.10
access-list 10 permit 10.0.0.0 0.0.0.255
access-list 100 permit tcp any host xxx.114.118.1 eq 3389
access-list 100 permit tcp any host xxx.114.118.2 eq 3389
access-list 100 permit tcp any host xxx.114.118.3 eq 5900
access-list 100 permit tcp any host xxx.114.118.4 eq 5900
access-list 100 permit tcp any host xxx.114.118.5 eq 3389
access-list 100 permit tcp any host xxx.114.118.10 eq 3389
access-list 100 permit udp any host xxx.114.64.210 eq isakmp
access-list 100 permit udp any host xxx.114.64.210 eq non500-isakmp
access-list 100 permit udp any host xxx.114.64.210 eq 10000
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any host-unreachable
access-list 100 permit icmp any any time-exceeded
access-list 101 deny ip 10.1.34.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 101 deny ip 10.1.35.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 101 permit ip 10.1.34.0 0.0.0.255 any
access-list 101 permit ip 10.1.35.0 0.0.0.255 any
access-list 101 permit ip 10.1.36.0 0.0.0.255 any
access-list 101 permit ip 10.0.0.0 0.0.0.7 any
access-list 102 permit ip 10.0.0.0 0.255.255.255 any
access-list 150 permit ip 10.0.0.0 0.255.255.255 172.16.0.0 0.0.0.255
route-map nonat permit 10
match ip address 101
09-14-2005 01:29 PM
For accessing resources or folders through the firewall, you can either use the Universal Naming Convention (UNC), entering \\resource_name, for example; or you can double-click the Network Neighborhood icon.
09-15-2005 10:46 AM
When the users are VPN they are essentially on the network. The accesslist applied to the crypto isakmp client configuration is ACL 150. ACL 150 reads -
access-list 150 remark ACL for crypto isakmp client configuration group
Shouldn't this be allowing all the traffice required to access net resources?
