ACL blocks www even when it's allowed
Ricky Sandhu
Level 3
Level 3
Hi everyone, I was wandering if anyone of you can help me with an issue I am having with an inbound ACL on my router's public interface. Even though I allow web traffic, it still blocks it as I am not able to surf out. What am I doing wrong?
ip access-list extended BLOCK
permit udp any eq bootps any eq bootpc
remark Block antispoofing
deny   ip host 255.255.255.255 any log
deny   ip 127.0.0.0 0.255.255.255 any log
deny   ip 10.0.0.0 0.255.255.255 any log
deny   ip 172.16.0.0 0.15.255.255 any log
deny   ip 192.168.0.0 0.0.255.255 any log
deny   ip any 10.0.0.0 0.255.255.255 log
deny   ip any 172.16.0.0 0.15.255.255 log
deny   ip any 192.168.0.0 0.0.255.255 log
remark permit web traffic
permit tcp any any eq www
remark allow reply to an echo request
permit icmp any any echo-reply
deny   icmp any any redirect
deny   ip any any
John Blakley
Can you post the counts for the acl?
sh access-list BLOCK
HTH, John *** Please rate all useful posts ***
Here you go, few extra PERMIT statements here as I had narrowed it down earlier
r-exp-lab-1#sh access-lists BLOCK
Extended IP access list BLOCK
    10 permit udp any eq bootps any eq bootpc
    20 deny ip host 255.255.255.255 any log
    30 deny ip 127.0.0.0 0.255.255.255 any log
    40 deny ip 10.0.0.0 0.255.255.255 any log
    50 deny ip 172.16.0.0 0.15.255.255 any log
    60 deny ip 192.168.0.0 0.0.255.255 any log
    70 deny ip any 10.0.0.0 0.255.255.255 log
    80 deny ip any 172.16.0.0 0.15.255.255 log
    90 deny ip any 192.168.0.0 0.0.255.255 log
    100 permit tcp any any eq www
    110 permit tcp any any eq 22
    120 permit udp any any eq isakmp (28 matches)
    130 permit esp any any (19 matches)
    140 permit gre any any
    150 permit udp any any eq non500-isakmp
    160 permit icmp any any echo-reply (6 matches)
    170 deny icmp any any redirect
    180 deny ip any any (199 matches)
Okay...a couple of things:
1. Are you trying to surf the web through the tunnel?
2. It doesn't look like you're allowing dns. Try adding:
ip access-list ext BLOCK
5 permit udp any any eq dns
Hi there, so I made some modifications and now it seems to be working.
remark gre tunnels permitted
permit esp any any
permit gre any any
deny   ip any any
I created a NAT ACL
ip access-list extended nat_control
deny   ip 172.18.0.0 0.0.255.255 10.0.0.0 0.255.255.255
deny   ip 172.18.0.0 0.0.255.255 172.16.0.0 0.0.255.255
deny   ip 172.18.0.0 0.0.255.255 192.168.0.0 0.0.255.255
deny   ip 172.18.0.0 0.0.255.255 211.128.0.0 0.0.255.255
deny   ip 172.18.0.0 0.0.255.255 199.126.0.0 0.0.255.255
permit ip 172.18.0.0 0.0.255.255 any
Created a route-map and applied nat_control to my outside interface
route-map primary_nat permit 10
description primary_nat
match ip address nat_control
match interface GigabitEthernet0/0
ip nat inside source route-map primary_nat interface GigabitEthernet0/0 overload
Also added an outbound inspect for http on GigabitEthernet0/0
