ACL clarification...i am a bit rusty...
I have an ACL like this
..... access-list 101 permit tcp any any eq 32100 log....
problem is I have to open it "WIDE TO THE WORLD"
I have a server behind the ROUTER ...192.168.0.34
So I tried
....access-list 101 permit tcp host 192.168.0.34 eq 32100 any log........
so it would JUST anwser to that server but it does not work...am I missing something??
Thanks...
18 Replies 18
Hi Paul...
First...I am not an Expert at all but I have tried to Educate myself as much as possible, doing a lot of reading on ACL's and how to implement them. So I do want you all to know that I really do appreciate your help and expertise on this.
Yes you are Correct I do have (3) machines behind the router 192.168.0.3, 192.168.0.7, 192.168.0.15
The only reason I put the DENY statements in there was that a PORT SCAN showed that they were OPEN, I am sure that once I get things right I should be able to remove them.
TRAFFIC:
192.168.0.3  VNC,  VPN,  VIDEO,  SSH
192.168.0.7  VNC,  VPN,  FTP,  SSH
192.168.0.8  VNC,  VPN,  WEB,  GPS,  SSH
I only have VPN SERVER installed on just 1 server
The Router has MAX Memory installed.
I know it is a lot of Traffic but my connection is 300Mbps/10Mbps
since this post has been idle for several weeks, I cannot figure out exactly what the original question was. Looking at your config, a zone based firewall might be better suited for what you are trying to achieve. Can you check if your IOS supports the global command
zone-member ?
If that is the case, I could alter the configuration you have sent...
HI There....
I have attached a copy of the CONFIG COMMANDS for you.....
I want to thank everyone for the help.... I am closing this Topic because I now have a Cisco 3925 Router.
So thanks to all
