ACL Configuration issue
skkabulhussain
Dear sir's,
We did configure the Access Control List on Cisco 1941 router when we try to configure ACL on it. it is not working IOS Version 15.2(2)T. we have other versions like Version 15.0(1)M1 it is working fine.
Kindly advice me what is the issue.
Many Thanks in advance.
is it an extended access list ? Do you mean you cannot configure the ACL, or you apply it and it doesn't work ?
Yes it is extended ACL. whenever I am configuring ACL on cisco 1941 model version 15.2(2)T it is not applying to interface Ge0/0. I mean it is not working.kindly let me know how to configure ACL on this version router.it will work if I am configuring the ACL on this version.kindly let me know what are the command to do it.
Many Thanks for your response.
I did some research, and your problem could be related to this bug. Try and update your IOS to one of the version listed in 'Known Fixed Releases'.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtt19027/?referring_site=bugquickviewredir
Hey,
you need to update your device....
