ACL Drop denied traffic rather than reply with icmp unreachable 3 Code 13
pfj
Hi there,
Platform: ASR1K/CSRv
Anyone know if you can DROP traffic that is denied on an inbound ACL.  Traffic that targeting legitimate hosts(so no pointing to Null 0).
I don't want to use the big hammer that is no ip unreachables. So that traceroute/PMTUD still work.
And denying icmp administratively-prohibited on the outbound ACL is not going to scale.  And seems like extra/unnecessary work.
In RFC 1812 it says:
"Routers SHOULD use the newly defined
Code 13 (Communication Administratively Prohibited) if they
administratively filter packets.
Routers MAY have a configuration option that causes Code 13
(Communication Administratively Prohibited) messages not to be
generated. When this option is enabled, no ICMP error message is
sent in response to a packet that is dropped because its forwarding
is administratively prohibited."
Does anyone know if Cisco implemented this silent DROP functionality specifically for Type 3 Code 13?
Cheers,
pfj
0 Replies 0
