ACL for NAT
jerry.mcrae
i am configuring nat on a 3825 running this ios C3825-ADVIPSERVICESK9-M), Version 12.4(7a). i have nat configured and i just need to allow the inside users access to the nat pool. examples im using use this format access-list 100 permit x.x.x.x x.x.x.x - but my ios uses this fromat access-list 100 permit ip (protocol) 10.10.0.0 0.0.255.255 any (dest add, any, host).
any suggestions?
i am 2 hours away from router and dont to kill my telnet session.
thanks in advance.
21 Replies 21
vijayasankar
Level 4
Level 4
If you could provide the config snapshot( excluding the sensitive informations, public ip..) it would helpful to assist you in the right direction.
Depending on your need you can either use a standard or extended ACL in this scenario.
If you just want to allow the inside users to get NAT'ed. then you can use the standard acl as follows.
For example:
access-list 10 permit 192.168.20.0 0.0.0.255
access-list 10 permit 192.168.10.0 0.0.0.255
Here the network 192.168.20.0/24 and 192.168.10.0/24 are the inside networks.
Ex:Create a dynamic nat in the global config
ip nat inside source list 10 interface overload
In this example, an ACL 10 is created to allow the inside subnets.
This ACL is called in the "ip nat inside" command. As per this example, the inside subnets will get natted to the ip address of the interface that is specified in the
Hope this helps. Rate the post if you find it useful.
Get back to us if you need further clarifications.
-VJ
check this out. i have ip nat inside and outside configed on the interfaces not shown in the example.
nat config:
ip nat pool ovrld 72.x.x.x 72.x.x.x prefix-length 29
ip nat inside source list 140 pool ovrld overload
ACL config attempt.
RFP3825(config)#access-list 140 permit 10.10.0.0 0.0.255.255
% Invalid input detected at '^' marker.
RFP3825(config)#access-list 140 permit 10.10.0.0 0.0.255.255 ?
% Unrecognized command
thanks,
You are trying with an extended ACL. ( ACL number above 100 are extended ones)
which requires you to specify a protocol, source ip, port, destination ip, port.
You have two options now.
access-list 140 permit ip 10.10.0.0 0.0.255.255 any
Or you can define a standard acl as stated above in my post, in which case you will only specify the source subnets.
Hope this helps. Rate the post if you find it usefull
-VJ
i attached my config. still cant get outside.
interface Serial0/1/1:0
description office 1
bandwidth 1544
ip unnumbered GigabitEthernet0/0.10
ip nat inside
ip virtual-reassembly
no cdp enable
interface Serial0/3/0:0
description Interface ISP
ip address 7.x.x.194 255.255.255.252
ip nat outside
ip virtual-reassemblyip forward-protocol udp 135
ip route 0.0.0.0 0.0.0.0 7.x.x.193
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool ovrld 72.166.80.169 72.166.80.169 prefix-length 29
ip nat inside source list 7 pool ovrld overload
logging 172.16.1.100
access-list 7 permit 172.19.1.0 0.0.0.255
access-list 7 permit 10.10.0.0 0.0.255.255
access-list 102 permit udp any any range 16384 37276
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
access-list 150 permit tcp any any eq www
i could see that you have enabled ip nat inside on the serial interface 0/1/1:0
Where are you networks 172.19.1.0/24 and 10.10.0.0/16 located.
I couldn't see any routes for these network in the config that you have posted.
If those networks are connected ethernet interfaces, then you should turn on "ip nat inside" under those interfaces.
Can you post the full config, to understand your setup.
Hope this helps.
-vJ
version 12.4
service password-encryption
boot-start-marker
boot system flash c3825-advipservicesk9-mz.124-7a.bin
boot-end-marker
card type t1 0 0
card type t1 0 1
card type t1 0 3
logging buffered 1000000 debugging
no aaa new-model
resource policy
clock timezone MST -7
clock summer-time MDT recurring
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 3
network-clock-select 1 T1 0/0/0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.132.0 192.168.132.50
ip host switch 172.19.1.5
isdn switch-type primary-ni
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
framing esf
linecode b8zs
description FUTURE PRI
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
description
controller T1 0/1/1
framing esf
linecode b8zs
description
controller T1 0/3/0
framing esf
linecode b8zs
description INTERNET T1
controller T1 0/3/1
framing esf
linecode b8zs
description FUTURE INTERNET T1
class-map match-all voice-signaling
match ip dscp af31
class-map match-all voice-traffic
match ip dscp ef
policy-map E_SP
class voice-traffic
priority 800
class voice-signaling
bandwidth 8
class class-default
fair-queue
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/0.10
description VLAN 10 for Data
encapsulation dot1Q 10
ip address 172.19.1.1 255.255.0.0
ip nat inside
no snmp trap link-status
interface GigabitEthernet0/0.15
description VLAN 15 for Voice
encapsulation dot1Q 15
ip address 192.168.132.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
negotiation auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/0:0
description
bandwidth 1544
ip nat inside
no cdp enable
service-policy output E_SP
description
bandwidth 1544
ip nat inside
no cdp enable
interface Serial0/2/0
description
bandwidth 1544
no cdp enable
ip address 7.x.x.x 255.255.255.252
ip nat outside
router eigrp 100
network 172.19.0.0
network 192.168.132.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 172.16.1.1
no ip http server
ip nat pool ovrld 7.x.x.x 7.x.x.x prefix-length 29
snmp-server community
control-plane
voice-port 0/0/0:23
mgcp profile default
The Config looks ok for me. Is it working or are you facing any problems
Can you post the output of "show ip nat translations".
-VJ
here you go.
sh ip nat translations
Pro Inside global Inside local Outside local Outside global
tcp 72.x.x.x:1346 172.19.1.62:1346 67.x.x.x:65181 67.x.x.x:6518
tcp 72.x.x.x:4823 172.19.1.78:4823 216.239.x.x:5222 216.239.x.x:522
Hii jerry,
to more concise pls clarify ur internal and global ip's for better clarification so that we can help u out..
i added ip nat inside to a sub interface thats for data traffic. i wonder if that is a problem. see config below.
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
ip nat inside
Jerry,
According to the nat translation output, NAT is taking place. However, I saw in the permit statement that you are only allowing 172.19.1.0/24 to get translated with this command
while you have ip address 172.19.1.1 255.255.0.0 on the G0/0.10 interface.
For instance, this IP 172.19.1.62 is able to get out to the internet according to your NAT table.
i'll test and post results later this weekend.
thanks.
i still cant get out to the net. i'm sure nat is working so i think it's an ACL now.
my router has these ACL configed:
sh access-lists
Standard IP access list 7
10 permit 172.19.1.0, wildcard bits 0.0.0.255
20 permit 10.10.0.0, wildcard bits 0.0.255.255
Extended IP access list 102
10 permit udp any any range 16384 37276
Extended IP access list 103
10 permit tcp any eq 1720 any
20 permit tcp any any eq 1720
Extended IP access list 150
10 permit tcp any any eq www (720 matches)
thanks
