acl issue
shenmaia24
Cisco C819G-LTE-LA-K9 (revision 6.0) with 883788K/33715K bytes of memory.
Processor board ID FGL212190NG
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
3 terminal lines
1 Virtual Private Network (VPN) Module
2 Cellular interfaces
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
Hi im facing problem to ping my core router from laptop ip that connected to cisco C819G-LTE-LA-K9.
inside cisco router C819G-LTE-LA-K9 able to ping core router
from laptop able to ping cisco router connection lan fastethernet 0.
From core router able to ping cisco router
from core failed to ping laptop ip.
when do tracert from laptop to ip core router it stuck at fastethernet gateway ip.
*already check laptop firewall already turn off
*connection between cisco to my core router using ipsec
below my config
interface FastEthernet0
switchport access vlan 2
no ip address
interface Vlan2
description to laptop
ip address 10.60.107.222/30
my core router ip 192.168.x.x/24
Please someone guide me
6 Replies 6
Deepak Kumar
As per your below configuration:
below my config
no ip address
interface Vlan2
where is 192.168.x.x/24 configuration?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak
 192.168.x.x/24 is my remote address(core router) that connected cisco router using ipsec.im able to ping remote address from cisco. only failed when ping from laptop to remote ip(core router)
Share your VPN ACL and NAT Acl configuration.
Deepak Kumar
Deepak Kumar,
Below ACL that only i config on my cisco
VPN ACL
ip access-list extended cisco
permit ip host 20.0.0.110 any
permit ip 10.60.0.0 0.0.0.255 any
permit ip host 10.17.19.249 any
PERMIT ip 10.60.107.220 0.0.0.3 any
Please add missing ACL entry and try. I hope it will resolve otherwise please share full router configuration.
Deepak Kumar
Deepak Kumar,
still no work. after run config as per advice connectivity between cisco and core router lost.
Below full config
Building configuration...
Current configuration : 9982 bytes
version 15.6
hostname shen
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
lte sim data-profile 2 attach-profile 2 slot 1
lte failovertimer 1
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
track 10 ip sla 10
delay down 150 up 150
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key XXXX address XXXX
crypto isakmp nat keepalive 20
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set test esp-3des esp-md5-hmac
mode tunnel
crypto map myalif 10 ipsec-isakmp
set peer XXXX
set transform-set alif
match address alif
dlsw local-peer peer-id 20.0.0.110
dlsw remote-peer 0 tcp 30.2.2.251
dlsw remote-peer 0 tcp 30.2.2.250
dlsw remote-peer 0 tcp 10.123.1.2
dlsw remote-peer 0 tcp 30.2.2.253
dlsw remote-peer 0 tcp 20.2.1.138
dlsw remote-peer 0 tcp 30.2.2.254
dlsw remote-peer 0 tcp 20.2.1.147
dlsw remote-peer 0 tcp 20.2.1.145
dlsw remote-peer 0 tcp 30.1.1.2
dlsw remote-peer 0 tcp 30.1.1.3
dlsw remote-peer 0 tcp 10.125.1.2
dlsw bridge-group 1
interface Loopback0
ip address 20.0.0.110 255.255.255.255
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
no ip route-cache cef
load-interval 60
dialer in-band
dialer pool-member 2
dialer-group 1
async mode interactive
interface Cellular1
no ip address
encapsulation slip
no ip address
interface GigabitEthernet0
description test-ip
ip address 10.180.8.1 255.255.255.240
duplex auto
speed auto
interface Serial0
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.128
ip tcp adjust-mss 1452
interface Vlan2
description laptop LAN
ip address 10.60.107.222 255.255.255.252
interface Dialer1
description << Dialer associated with Cellular Interface >>
no ip redirects
no ip proxy-arp
ip nat outside
dialer pool 2
dialer string lte
dialer watch-group 1
dialer-group 1
no cdp enable
crypto map test
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended alif
ip sla auto discovery
ip sla 10
icmp-echo 192.168.14.26 source-interface Loopback0
timeout 15000
ip sla schedule 10 life forever start-time now
dialer watch-list 1 ip 1.1.1.1 255.255.255.255
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 10
dialer watch-list 1 delay disconnect 20
dialer-list 1 protocol ip permit
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
event manager applet sim_toggle
event tag e1 track 10 state down
event tag e2 timer countdown time 120
trigger
correlate event e1 or event e2
action 1.0 track read 10
action 1.1 if $_track_state eq "down"
action 1.2 info type snmp oid 1.3.6.1.4.1.9.9.661.1.3.2.1.18.12 get-type exact
action 1.3 syslog msg "Carrier is "
action 1.4 set x "$_info_snmp_value"
action 1.5 cli command "enable"
action 1.6 if $x eq "celcom" goto primary
action 1.7 syslog msg "XXXXX Network Issue. Switching to YYYYY"
action 1.8 cli command "clear interface cellular 0"
action 1.9 cli command "cellular 0 LTE sim activate slot 1"
action 2.0 else
action 2.1 syslog msg "YYYY Network Issue. Switching to YYYY"
action 2.2 cli command "clear interface cellular "
action 2.3 cli command "cellular 0 LTEsim activate slot 0"
action 2.4 end
action 2.5 cli command "do clear ip route *"
action 2.6 cli command "do show ip sla statistics"
action 2.7 cli command "do show ip route"
action 2.8 cli command "do show ip interface brief"
action 2.9 end
event manager applet Failback
event timer watchdog time 3600
action 1.0 info type snmp oid 1.3.6.1.4.1.9.9.661.1.3.2.1.18.12 get-type exact
action 1.1 syslog msg "Carrier is $_info_snmp_value"
action 1.2 set x "$_info_snmp_value"
action 1.3 cli command "enable"
action 1.4 if $x eq "YYYYY"
action 1.5 syslog msg "Activating DIGI Sim Card"
action 1.6 cli command "clear interface cellular "
action 1.7 cli command "cellular 0 LTE sim activate slot 0"
action 1.8 cli command "do clear ip route *"
action 1.9 cli command "do show ip sla statistics"
action 2.0 cli command "do show ip route"
action 2.1 cli command "do show ip interface brief"
action 2.2 end
end
