IPSec on ASR920
Bernard Tabib
Hello
   Does the ASR-920-12SZ-IM support IPSec encryption to allow payload encryption now ?
thanks
divanko
I found this info about IPSEC encryption on the Cisco ASR-920-12SZ-IM:
  • IPSec
Starting with Cisco IOS-XE Release 3.18S, IPsec tunnel is supported only on the Cisco ASR920-12SZ-IM router with payload encryption (PE) images.
Source:
http://www.cisco.com/c/en/us/td/docs/routers/asr920/release/notes/ASR920_rel_notes/new_features.html
What about the ASR-920-4SZ? Do it support IPSec or not?
EDIT: Nevermind. "supported only on the Cisco ASR920-12SZ-IM routers"
caciviog
Is available use WAAS on ASR920? in what feature?
as far as I used the Cisco Feature Navigator properly, there is no WAAS feature on the ASR920.
https://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
