ACL logs
Ibrahim Jamil
Level 6
Level 6
Hi Experts
i have an ACL 150 applied to Gi0/0 inbound direction,  with a log keyword on the deny line,now how can i see  the effects of this ACL,i mean the src address being blocked by acl
thanks
jamil
John Blakley
Jamil,
It will either log to your buffer or wherever you're sending your logs (if you're using a syslog server). You can do a show log to see the results usually.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John
thanks for ur reply
i dont have a syslog server!
Can we go further, i need to debud this ACL ?
jamil
Try just "show log" on the router.
Hi Ibrahim,
You should have activated the logging to the buffered. In addition, you should configure the log to  debugging severity level if you need to also log the debug outputs.
Finally, I would recommned to increase the buffer size to a higher value than the default (4096) in order to avoid overwriting the logs
logging buffered [buffer-size| level]
level=7 debugging
Hope that helps,
Vasilis
