ACL minimal entry question
news2010a
Level 3
Level 3
Imagine you need to write an ACl, using minimal commands, wtihout any leakage, to permit this (without using a calculator):
106.157.10.0/24
106.181.22.0/24
107.189.11.0/24
107.245.23.0/24
The way I approach this is that I would try to write one entry for:
106.157.10.0/24
106.181.22.0/24
and another entry for
107.189.11.0/24
107.245.23.0/24
Doing And and XOR operation on the 106.157.10.0/24 and 106.181.22.0/24 I come up with:
access-list 1 permit 106.149.2.0 0.40.28.0
and  doing And and XOR operation for the second group 107.189.11.0/24 and 107.245.23.0/24 it is:
access-list 1 permit 107.181.3.0 0.72.28.0
However, if I validate this using the subnet calculator, I see lot of other IP addresses got included (see bottom below).
So my conclusion is, the only way to avoid leakage is really writing four entries in the access lists like below. Am I wrong or someone here is capable to consolidate this in less than 4 statements?
access-list 1 permit 106.157.10.0 0.0.0.255
access-list 1 permit 106.181.22.0 0.0.0.255
access-list 1 permit 107.189.11.0 0.0.0.255
access-list 1 permit 107.245.23.0 0.0.0.255
w.Boson.com Wildcard mask checker
IP Address:    106.149.2.0
Wildcard mask: 0.40.28.0
First Octet Match(es)
106
Second Octet Match(es)
149
157
181
189
Third Octet Match(es)
18
22
26
30
Fourth Octet Match(es)
IP Address:    107.181.3.0
Wildcard mask: 0.72.28.0
107
181
189
245
253
11
15
19
23
27
31
Ruchir Jain
I guess the best you could do is groping first and third address together and second and fourth one together:
access-list 1 permit 106.157.10.0 1.32.1.0
This is what it matches:
106
107
157
189
access-list 1 permit 106.181.22.0 1.64.1.0
106
107
181
245
22
23
Ruchir
