ACL question
NetMaxKar
Hello.
I have below case:
interface FastEthernet0/0
description INTRANET
ip address 10.20.28.1 255.255.252.0
ip nat inside
duplex auto
speed auto
interface Serial0/0.3 point-to-point
dexcription INTERNET
ip address <real_ip> 255.255.255.192
ip nat outside
frame-relay interface-dlci 404
interface FastEthernet0/1
description DMZ
ip address real 255.255.255.192
duplex auto
speed auto
I want:
to allow only telnet from INTERNET to DMZ.
to allow ALL traffic from DMZ and INTRANET to INTERNET.
Pleas, help me with ACL rules...
19 Replies 19
To control DMZ to intranet traffic use this access-list
access-list 101 permit udp "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255 eq snmp
access-list 101 permit udp "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255 eq snmptrap
access-list 101 permit deny ip "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255
access-list 101 permit ip "DMZ Subnet" 0.0.0.63 any
apply it on the DMZ interface in an inbound direction.
interface fa0/1
ip access-group 101 in
To allow the other traffic use an acl for the serial interface and apply it in an inbound direction.
What you need to do is this
access-list 102 permit tcp any "DMZ Subnet" 0.0.0.63 eq ssh
access-list 102 permit tcp any "DMZ Subnet" 0.0.0.63 eq smtp
etc... add lines for all the traffic from the Internet to your DMZ servers.
access-list 102 deny ip any "DMZ Subnet" 0.0.0.63 # deny any other traffic to the DMZ servers
access-list 102 permit ip any any # allow all other return traffic
interface s0/0.3
ip access-group 102 in
the only other issue is echo. if you really want to allow ping from any internet machine to your DMZ servers
it is not
access-list 120 permit tcp any any eq echo
access-list 120 permit udp any any eq echo
it is
access-list 102 permit icmp any "DMZ Subnet" 0.0.0.63 echo
This is not a particularly good thing to do. It allows people on the Internet to work out which machines you
have on public addressing.
Last point. The access-list 102 allows ftp, ssh etc. to all the servers in the DMZ. Presumably you don't have all
services running on all servers ie. say smtp was running on only one server. instead of
a more secure access-list would be
access-list 102 permit tcp any host "SMTP Server ip address" eq smtp
Jon
One slight change to the above. if you want any traffic to be allowed from the DMZ to the Internet but only the specified ports from the internet to the DMZ
In our access-list 102 BEFORE the line
access-list 102 deny ip any DMZ Subnet" 0.0.0.63
you need the line
access-list 102 permit tcp any "DMZ Subnet" 0.0.0.63 established
This will allow the DMZ to initiate tcp connections to the Internet.
There is still a problem with non-tcp traffic initiated from the DMZ to the internet.
If there are any other connections that are initiated from the DMZ to the Internet you will need to account for the return traffic in your acl on the outside interface before you deny ip to the DMZ subnet.
The same applies to the intranet to the DMZ traffic.
You need to add to access-list 101 before the line
access-list 101 permit tcp "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255 established.
This is why firewalls are quite useful - they are stateful so you don't need to account for return traffic in the same way !.
Jon
access-list 101 permit deny ip ...
What does it mean permit deny?
Sorry, that would be a typo.
It's meant to be "access-list deny ip...."
Jon
jitesh1982
Hello Max,
After such a long work I would like to know have your problem resolved, or uptill were you r to mark, so that I can try to help it out.
Rgds,
Jitesh
