ACL restrictions in Router
amrendraks
Hi everyone,
I have given my router config below,
My case is :
as per ACL defined, I am able to communicate with the host/network, but my router is not able to communicate to another side client although the ACL allows the range of IP where router falls,
May I know from you all what is remaining in my configuration.
side A : 192.168.10.x/16 ( fa/0/0)
Side B : 192.168.20.x/16 ( fa/0/0 )
rotuer are on : 172.16.10.x/24
and routing the packets for communicating the hosts/LAN.
Thanks .
Router Config :
Building configuration...
Current configuration : 1888 bytes
version 12.4
service password-encryption
hostname SL
boot-start-marker
boot-end-marker
no logging console
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
multilink virtual-template 1
username amar password 7 XXXXXXXXXXX
username sl password 7 XXXXXXXXXXX
interface FastEthernet0/0
ip address 192.168.10.6 255.255.0.0
ip access-group 101 in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
bandwidth 2048
no ip address
encapsulation ppp
pulse-time 3
ppp multilink
interface Serial0/1/0
bandwidth 2048
no ip address
encapsulation ppp
pulse-time 3
ppp multilink
interface Serial0/1/1
bandwidth 2048
no ip address
encapsulation ppp
pulse-time 3
ppp multilink
interface Virtual-Template1
ip address 172.16.10.1 255.255.255.0
ppp multilink
ip classless
ip route 192.168.20.0 255.255.255.0 172.16.10.2
ip route 192.168.60.0 255.255.255.0 172.16.10.2
ip http server
access-list 101 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 101 permit ip host 192.168.10.1 192.168.60.0 0.0.0.255
access-list 101 permit ip host 192.168.10.3 192.168.60.0 0.0.0.255
access-list 101 permit ip host 192.168.10.4 192.168.60.0 0.0.0.255
access-list 101 permit ip host 192.168.10.8 192.168.60.0 0.0.0.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 172.16.10.0 0.0.0.255
control-plane
banner motd ^CINE "Welcome to SHUSHANT ^C
line con 0
line aux 0
line vty 0 4
warm-reboot
end
6 Replies 6
mahmoodmkl
Level 7
Level 7
i dnot think that u need this long list of access-list.only the first and the last statement are enough.
Do u have any access-list placed at the other end.Remember the implicit deny statement at the end of the access-list.
The other end router config would provide more information.
Mahmood
mleeman
If you are trying to ping or telnet from the router. Your router will use the IP of the outbound interface. In this case 172.16.10.1. You will need this IP range in your config.
If you are trying to ping or telnet from the router. Your router will use the IP of the outbound interface. In this case 172.16.10.1. You will need this IP range in your ACL.
Thanks for your prompt reply, but see
from both side allowed LANs/Hosts are able to do all the operations, means routers are allowing the packets, but router itself is not able to ping clients of either side but they do for routers each other, is my implication.
The router will use the exiting interface IP as the source. If you do this, it will use the FA0/0 as the source.
Router A#ping
Protocol [ip]:
Target IP address: 192.168.20.X (client IP)
!--- The address to ping.
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.10.6
Amrendra
I can not understand clearly what is working (if anything) and what is not working. Can you clarify whether the router in 192.168.10.x can access the router in 192.168.20.x and whether the router in 192.168.10.x can access clients in 192.168.20.x? Also whether clients in 192.168.10.x can access the router in 192.168.20.x and can access clients in 192.168.20.x?
Based on what I think I understand about the symptoms my first guess would be that there might be a problem with configuration of default gateway on the end stations (it could be on either side or on both sides that there is a problem). Can you verify that the end stations have the correct default gateway configured?
Can you also verify that the multilink is working ok?
Rick
Rick
