SUP Card
deepaknagi
I have MSFC card with 7 ports in 6506 switch. It is possible to connect 4507 switch so MSFC acts as a uplink. Kindly advice?
royalblues
Level 10
Level 10
Do you mean the uplinks of the supervisor card?
MSFC is a daughter card inside the supervisor.
The ports on the supervisor card can be used for uplinks as any other module.
you can connect your 4507 to any of the supervisor card uplink ports.
HTH, rate if it does
Narayan
