ACL Standard in
chrissnop
H guys, standard acl is 1 - 99.
If I create two acl number 1 and 2, does it mean that only one of them will be active or will be processed?
What I mean is:
int g0/0
ip access-group 1 in
ip access-list standard 1
deny ip x.x.x.x
 .....some more IPs
Then I have another acl
int g0/0
ip access-group 2 in
ip access-list standard 2
deny ip y.y.y.y
 .....some more IPs
The two acl 1 and 2 are applied to int g0/0, direction is 'in'.
Both ACL will be processed? or only the newest one that was created and applied?
Thanks for any input.
johnlloyd_13
Level 9
Level 9
hi,
there's a violation with your setup.
there's a rule of thumb which applies for ACL:
only one rule per protocol, per direction, per interface.
johnlloyd_13
Level 9
Level 9
hi,
Thanks, Johnlloyd. :)
Hi guys, extremely sorry for hijacking this thread but it won't let me create a new discussion :-/
I wonder if someone can point me in the right direction. I'm setting up a lab with a more complex setup and am having issues I believe I've isolated to access list configuration on a VPN concentrator
Would a duplication of access rules prevent connection to a host? Here is the config I've put together, further information below:
Extended IP access list 2664
    10 permit ip 10.56.0.0 0.0.255.255 172.16.138.10 0.0.0.7 (62583 matches)
    20 permit ip 10.57.0.0 0.0.255.255 172.16.138.10 0.0.0.7
    30 permit ip 10.148.4.0 0.0.0.255 172.16.138.10 0.0.0.7 (7990 matches)
    40 permit ip 10.148.5.0 0.0.0.255 172.16.138.10 0.0.0.7 (5111 matches)
    50 permit ip 10.148.6.0 0.0.0.255 172.16.138.10 0.0.0.7
    60 permit ip 10.148.1.0 0.0.0.255 172.16.138.10 0.0.0.7 (8 matches)
    70 permit ip 10.148.4.0 0.0.0.255 172.16.166.20 0.0.0.7 (216 matches)
    80 permit ip 10.148.5.0 0.0.0.255 172.16.166.20 0.0.0.7 (87 matches)
    90 permit ip 10.148.6.0 0.0.0.255 172.16.166.20 0.0.0.7
    100 permit ip 10.148.1.0 0.0.0.255 172.16.166.20 0.0.0.7
Extended IP access list 2665
    10 permit ip 10.56.0.0 0.0.255.255 172.16.166.20 0.0.0.7 (731093 matches)
    20 permit ip 10.57.0.0 0.0.255.255 172.16.166.20 0.0.0.7
So, the two hosts I'm trying to connect to are 172.16.166.20 and 172.16.138.10
The subnets 10.56 and 10.57 can connect absolutely fine, which is why I'm thinking by duplicating the permit rules for 10.148.4.0, 10.148.5.0, 10.148.6.0 and 10.148.1.0 in both access lists, I'm somehow stopping this from working.
Assistance would be greatly appreciated.
