ACL to prevent InterVLAN Routing and enable access to Internet
RMS3
Hi All,
I have multiple VLANs and OSPF running on a L3 Switch. I want to prevent VLAN's 1,2 and 3 communicating with each other but each of the VLAN's should reach an external network via OSPF.
I tried configuring an ACL to prevent inter-VLAN routing but in that case my connection to the external network is also lost.
ip access-list extended AAA
deny ip any <SVI of VLAN B>
permit ip any any
exi
int vlan A
ip access-group AAA in
exi
I have tried to block just one VLAN for now but not successful.
Could anyone please help me with it?
15 Replies 15
@Joseph W. Doherty wrote:
@MHM Cisco World wrote:
Acl apply to SVI can  not filter traffic toward SVI İp but it can filter traffic bypass SVI.
Oh?  Hmm, I didn't know that.  I'll set up a lab to confirm that.
(PT) Lab results:
I was able, on a SVI (in PT) block ingress echo requests, while allowing echo request to transit the interface.  So, it appears you CAN filter traffic to the SVI IP, itself.
switch#sh cdp n
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
Switch Gig 1/0/1 144 3650 Gig 1/0/1
Relevant L3 switch config snippets:
Switch0:
ip routing
interface Loopback0
ip address 192.168.2.1 255.255.255.255
interface GigabitEthernet1/0/1
interface Vlan1
ip access-group test in
ip access-list extended test
deny icmp any host 192.168.1.1 echo
permit ip any any
Switch1:
ip routing
no switchport
ip address 192.168.1.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.1.1
Pinging Switch0's SVI IP from Switch1:
Switch#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
Pinging Switch0's Loopback0 IP from Switch1:
Switch#ping 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/0 ms
