ACL to prevent InterVLAN Routing and enable access to Internet
RMS3
Hi All,
I have multiple VLANs and OSPF running on a L3 Switch. I want to prevent VLAN's 1,2 and 3 communicating with each other but each of the VLAN's should reach an external network via OSPF.
I tried configuring an ACL to prevent inter-VLAN routing but in that case my connection to the external network is also lost.
ip access-list extended AAA
deny ip any <SVI of VLAN B>
permit ip any any
exi
int vlan A
ip access-group AAA in
exi
I have tried to block just one VLAN for now but not successful.
Could anyone please help me with it?
2 Accepted Solutions
deny ip 10.169.10.128 255.255.255.192
any (check @Richard Burts note about wildcard)
permit ip any any
int vlan 100
ip access-group VLAN_A OUT
15 Replies 15
Richard Burts
From a high level your access list looks appropriate. But we do not have enough detailed information to identify the issue you are experiencing. Assuming that your vlans are using private addressing please tell us the IP addressing of the vlans (there is no need to disguise private addressing). And please post the exact syntax of your acl (
<SVI of VLAN B>
hides details that we need to know).
Rick
Thanks for the response,let me add that in
ip access-list extended VLAN_A
deny ip any 10.169.10.128 255.255.255.192
permit ip any any
exit
int vlan 100
ip access-group VLAN_A in
exit
Acl apply to SVI can  not filter traffic toward SVI İp but it can filter traffic bypass SVI.
Here you can config acl in link toward aaa server not in SVI.
Hi ,
Thanks for the response,that was just a poor way of naming my ACL.
I have posted the exact config,please check above thread.
10.169.10.128 <<- this for SVI vlan B?
If yes then only make acl direction OUT not IN
Yes it is the
SVI for VLAN B
,do we have to retain the
permit ip any any?
I can still communicate between VLANs even after I change acl to OUT
Can I see last config and
IP of svi vlan a and b
The biggest issue is the mask used
which is a subnet mask. ACL should use
mask 0.0.0.127.
The access-group could be applied either IN or OUT. Whether the vlan B subnet is the source address or the destination address will depend on whether it is applied IN or OUT. If applied IN then it examines traffic come from connected hosts into the switch and vlan B wold be destination. If applied OUT then it examines traffic going from switch out to connected hosts and vlan B source.
And yes you do need to keep the
permit ip any any
Rick
permit ip any any
int vlan 100
Thanks for the help.
I tried the suggested solutions on Packet Tracer and it worked. However I missed a very important detail.
I am running HSRP on two L3 switches where I am applying the ACL. Should I use the HSRP VIP or the SVI of each VLAN in the ACL.
Both.
Thanks that worked.
But as I am running HSRP I believe the HSRP packets are getting filtered out as well.
%HSRP-5-STATECHANGE: Vlan10 Grp 2 state Standby -> Active
*Sep 28 11:25:44.902 UTC: %OSPF-5-ADJCHG: Process 3, Nbr 10.169.10.227 on Vlan410 from INIT to DOWN, Neighbor Down: Dead timer expired
I believe this is the reason my hosts cannot reach the network.
Could you please help me fix this?
Instead of deny the
IP deny udp 1812/1813
the
udp port
use by
aaa radius server
Oh?  Hmm, I didn't know that.  I'll set up a lab to confirm that.
