ACLs doesnt work, trying to block ICMP in testlab
trane.m
As title states, i'm trying to block WinServer19 from sending ICMP packets to PC1 in VLAN10. My lab looks like this:
In this picture it doesn't show, but there is a portchannel 2 between SRVACC and Core1, also a portchannel 1 between Core switches. On Core1, i configured this ACL:
When i first tried to apply it to portchannel 2, it wouldn't work, i was still able to ping from WinServer19, so i also applied it to G2/2 and G2/3.
From WinServer19, i can still ping PC1, Core1, google and whatever else i tried. Why is it not working?
where is VLAN50s gateway configured? map your ACL to VLAN50s gateway SVI in bound.
Good luck
KB
Yes of course, i totally missed that! Thank you! it works!
good. if it resolved the issue, please mark this as a solution.
Good luck
KB
if you run HSRP or GLBP then you must apply ACL in SVI in both Core.
