ACLs have a weird behaviour - Cisco Packet Tracer
FAB1150
I'm completely new to ACLs, so I apologize if the solution is obvious.
I attached the packet tracer project, I'm trying to set up some ACLs on the core switches to manage inter-VLAN routing and VLAN access to the "WAN".
For now I have applied the following ACLs:
ip access-list extended UFFICI
 100 permit ip 192.168.4.0 0.0.0.255 192.168.0.0 0.0.255.255
 200 permit udp 192.168.1.0 0.0.0.255 3.3.3.2 0.0.0.0 eq 67
 210 permit udp 192.168.2.0 0.0.0.255 3.3.3.2 0.0.0.0 eq 67
 220 permit udp 192.168.3.0 0.0.0.255 3.3.3.2 0.0.0.0 eq 67
 230 permit udp 192.168.4.0 0.0.0.255 3.3.3.2 0.0.0.0 eq 67
 310 permit tcp 192.168.1.0 0.0.0.255 100.0.0.10 0.0.0.0 eq 443
 320 permit tcp 192.168.3.0 0.0.0.255 100.0.0.10 0.0.0.0 eq 443
 330 permit tcp 192.168.4.0 0.0.0.255 100.0.0.10 0.0.0.0 eq 443
 400 permit udp 192.168.1.0 0.0.0.255 100.0.0.50 0.0.0.0 eq 69
 410 permit udp 192.168.1.0 0.0.0.255 100.0.0.50 0.0.0.0 eq 69
 420 permit udp 192.168.1.0 0.0.0.255 100.0.0.50 0.0.0.0 eq 69
 430 permit udp 192.168.1.0 0.0.0.255 100.0.0.50 0.0.0.0 eq 69
 500 permit ip 192.168.0.0 0.0.15.255 192.168.0.0 0.0.15.255
 1000 deny ip any any
exit
interface vlan 101
 ip access-group UFFICI out
interface vlan 102
interface vlan 103
interface vlan 104
The exercise is:
  • VLANs 101, 102, 103 have to be able to access all the VLANs in their "zone" (1xx) but not the others. VLAN 104 can access all the other VLANs
  • VLANs 101, 103, 104 have to be able to reache the web server (100.0.0.10) in HTTPs, not HTTP, and the TFTP server (100.0.0.50)
  • VLAN 102 can access the TFTP server but not the web server
  • all VLANs in zone 1 (id 1xx) can access the DHCP server
I'm not sure if I'm doing something wrong or if it's Packet Tracer, but I'm not getting the expected behavior at all- computers can't reach the HTTPs server but (sometimes) can reach the DHCP server, vlan 104 can't reach the other zones, and sometimes the VLANs in zone 1 can't see each other. What am I not getting?
thanks for the help!
Martin L
It is great that u use
Rapid-pvst
but use also
portfast default
command so that PCs get IPs before switch port times out.
PC in vlan 101 zone 1 can ping PC in vlan 104 zone 1
HTTPS traffic from
PC 192.168.1.22 in zone 1 to web server 100.0.0.10
is blocked by ACL on switch CO2 and CO1 Note return traffic may be load balance here ?.  I would add/edit  line to ACL UFFICI on both L3 switches with :
98 permit tcp host 100.0.0.10 eq 443 192.168.1.0 0.0.0.255
to allow HTTPS traffic back to vlan 101 PC.
IN general I am against using ACL on L3 switching.  Per ACL Rules of Extended ACL placement (as close to source as possible), I would suggest using router and not l3 switch.
Regards, ML
**Please Rate All Helpful Responses **
what is VLAN SVI IP ?
IPs are:
192.168.0.0/16
	192.168.0.0/20   -> Zona 1 (.0.x - .15.x)
		VLAN 101: 192.168.1.0/24	Direzione 	(DHCP on the server)
		VLAN 102: 192.168.2.0/24	Ingegneria 	(DHCP on the server)
		VLAN 103: 192.168.3.0/24	Marketing 	(DHCP on the server)
		VLAN 104: 192.168.4.0/24	IT 		(DHCP on the server)
	192.168.16.0/20  -> Zona 2 (.16.x - .31.x)
		VLAN 201: 192.168.16.0/24	MUtensili
		VLAN 202: 192.168.17.0/24	ComputerLN 	(DHCP on the server)
	192.168.32.0/20 -> Zona 3 (.32.x - .47.x)
		VLAN 301: 192.168.32.0/24	ComputerMGZ 	(DHCP on the server)
	192.168.48.0/20 -> services (.48.x - .63.x)
		VLAN 401: 192.168.48.0/24	VOCE		(local DHCP)
		VLAN 402: 192.168.49.0/24	WiFi		(DHCP on the server)
		VLAN 403: 192.168.50.0/24	Videosorveglianza
	192.168.255.0/29 -> Router to core switches
		192.168.255.0/30 -> PTPCO1
			192.168.255.1	ROUTER 	gi0/1/0
			192.168.255.2	CO1	gi1/1/3
		192.168.255.4/30 -> PTPCO2
			192.168.255.5	ROUTER	gi0/1/1
			192.168.255.6	CO2	gi1/1/3
WAN:
- Web server: 100.0.0.10
- TFTP server: 100.0.0.50
- DHCP server: 3.3.3.2
Martin L
Rapid-pvst
but use also
portfast default
HTTPS traffic from
Regards, ML
thanks for the advice! I think I'm starting to get it
