ACS failover
kzhen
We have two ACS servers. Our goal is to make one ACS to setup as primary and the second one as standby on the routers & switches, so when the primary is down, we can login the equipment via the secondary ACS without any issues. But it seems it doesn't work properly. If the primary ACS is down or disconnected, we are not able to login the switch Here is part of configuration on the router.
tacacs-server host 192.168.100.1 key cisco
tacacs-server host 192.168.100.2 key cisco
Please help.
Thank you.
Ganesh Hariharan
What is the failed attempts logs says in secondary ACS when request comes to secondary in absence of primary.
check out the connectivity between secondary ACS and switches and as well TACAS port reachablity between the two it should work.
Ganesh.H
