Add fastEthernet port to 1841 router
Singapore1629
I have the picture of a network I have to build, so I guess I need 3 fastEthernet ports, but 1841 has only 2. How to add another one? Any information can help me please.
Joseph W. Doherty
You could use the hwic-4esw.  You'll need to define a SVI and assign a VLAN to it and the modules port.  You should than be able to route through the SVI/VLAN/Ethernet-port.
NetworkDave
Singapore1629,
For the 1841, you need either a 1-port HWIC (HWIC-1FE) or a 2-port HWIC (HWIC-2FE). Unfortunately Packet Tracer does not provide either as an option.
Alternatively, you could use a different model router. Such as the "PT-Router" (4 FastEthernet ports) or the "2811" (2 FastEthernet ports...Add a NM-1FE--TX module for a 3rd one). You could also add a HWIC-2T to an 1841 and use serial WAN links between the routers.
Is this for a pka, pkt, or customized Packet Tracer? If so what is the labs title. Please provide the zipped file and instructions.
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
