Configuring 1 router with 2 switches
RyanPowers9691
Using this topology and configuration.
How do I get PC1 to ping PC2? With this configuration I can only get PC1 to ping PC3. I've looked at tons of guides and seem to be following them perfect but cant get communication between PC1 and PC2...
NetworkDave
RyanPowers9691
PC1 (10.22.0.11/24) & PC3 (10.22.0.13/24) in VLAN22 can ping each other and their gateway (10.22.0.1/24)
PC1 (10.22.0.11/24) & PC3 (10.22.0.13/24) in VLAN22 can't ping PC2 (192.168.200.12) in VLAN200.
PC2 (192.168.200.12) in VLAN200 can't ping its gateway (192.168.200.1/24).
The most likely cause would be that PC2's ARP's are probably failing at S1. Is VLAN200 configured on S1?
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
13 Replies 13
did you configured sub interfaces in router? your configurations says s2 gi 0/1 configured as sub interfaces? is it router? if so, make sure PCs configured with correct gateway addresses.
Good luck
KB
My apologies, you're correct, the subinterfaces were configured on the router. I wrote the wrong name on the image. PC1 and PC3 are configured with gateway 10.33.0.1 and PC2 is configured with gateway 192.168.200.1. They're still not talking.
See post to the thread.
Sorry, typo again.. PC1 and PC3 gateway is 10.22.0.1 not 10.33.0.1.
PC1 and PC3 can ping their gateway. PC2 cannot ping its gateway.
All trunks have vlan 33 and 200 allowed.
balaji.bandi
best is remove on S2 G0/1 and g0/1.22 config
S2
config t
default interface gi0/1
interface gig0/1
sw mode access
switch access vlan 200
on S1
simply create 2 SVI vlan on S1
config t
ip routing
interface vlan 22
ip address 10.22.0.254 255.255.255.0
no shutdown
interface vlan 200
ip address 192.168.200.254 255.255.255.0
no shutdown
Point your PC devices to respected Gateway example :
10.22.0.0 network to 10.22.0.254
192.168.200.0 network to 192.168.200.254
BB
I'm unable to create an SVI on S1 as it is not a Layer 3 switch
If that case do the same on S2 stil that works
can you post show version from both the switches ?
BB
Can you post the output of these commands on the router:
show ip route
show arp
Rick
all config is OK there is no issue still
double check the port number and trunk, may be it cable issue
NetworkDave
{Message Resent}
RyanPowers9691,
The below listed information is taken from your previous posts:
PC1 (10.22.0.11/24) VLAN22 Gateway 10.33.0.1
PC3 (10.22.0.13/24) VLAN22 Gateway 10.33.0.1
PC2 (192.168.200.12/24) VLAN200 Gateway 192.168.200.1
R1 G0/1.22 (10.22.0.1/24) VLAN22
R1 G0/1.200 (192.168.200.1/24) VLAN200
The PC1 & PC3 gateway (10.33.0.1) doesn't match R1 G0/1.22 (10.22.0.1/24).
Perhaps this is a typo in the information you provided. Please check.
Can PC1/PC2/PC3 ping their respect gateways?
Also, What VLANs are allowed on the trunks?
{Message Resent}
NetworkDave
RyanPowers9691
Dave, thanks! I didn't have VLAN200 configured on S1. Once configured, I was then able to ping PC2 from PC1!
RyanPowers9691,
No Worries! I'm glad the prolem is solved. It's good that we (The Community) were able to meet the SLA (j/k).
