Add OSPF routes in the routing table
Martin Konov
Today I met a very strange case and I could not find : Why my OSPF routes are not added in my routing table? So, I received my OSPF routes by my ISP which used MPLS for transport. My CE (T_Router) router received in my routes in OSPF database but they are not added to the routing table. I already check the some parameters like : OSPF network type, Addressing and all are correct. Lets try to explain a bit more :
X.X.X.X   >>>>  Router Id Address of my ISP
T_Router#sh ip ospf database
               Router Link States (Area 2)
X.X.X.X    X.X.X.X    48          0x80000DE5 0x005F9F 6
               Summary Net Link States (Area 2)
10.161.118.203  X.X.X.X    1148        0x80000005 0x00DCBB
               Type-5 AS External Link States
X.X.X.X    X.X.X.X    759         0x80000007 0x00C4F2 3489669645
T_Router#sh ip route | i 10.161.118.203
                        **  NO ROUTE **
Thank you in advance !
bapatsubodh
Martin,
Probable cause could be if there is any local route-filter configured for OSPF process.
Another reason could be protocol with better admin distance has these subnets in this case OSPF learned routes will not be installed in routing table.
Try "clear ospf process.".
Also check outut of  command show ip route 10.161.118.203
And not sh ip route | inc 10.161.118.203
Exact host may not be available in the routing table. You may have some subnet that is reachable that contains this particular.
Last but not least check if there is any IOS bug.
Cheers...
Sudeep Valengattil
Hi Martin,
Do you have VRFs configured in the CE router. If thats the case, u may need to enable vrf-lite under ospf process, for the prefixes to get installed in Routing table.
"capability vrf-lite"
Sudeep
Martin Konov
Dear all,
Thanks for your answers.
The problem was in our ISP and I hope that it will be solved today.
