10-14-2015 06:57 AM - edited 03-05-2019 06:58 AM
I have an existing default route on a 6500. It is ip route 0.0.0.0 0.0.0.0 10.0.0.1. need to add a second default router of equal cost. Is it as simple as just adding the command ip route 0.0.0.0 0.0.0.0 192.168.0.1?
Thanks in advance! All replies rated
Solved! Go to Solution.
10-14-2015 07:33 AM
10-14-2015 07:33 AM
Yes.
Jon
10-14-2015 01:26 PM
Well that was easy! Thanks!!
