Adding a 2nd ISP
jason.mckolay
I just started working for a small company ~25 users
Scenario:  The upstairs and downstairs network are seperated. I would like to bring them together The cabling exists already
Downstairs and ALL of the phones run off a T1 with a 3 meg Up/Down
Upstairs has a 35Meg down / 3up cable modem.
Equipment:  I've got  a cisco 2800 router with a 2  interface 1 for the t1 and 1 that connects the wireless trunk switch for the phone system and 8 layer 2 Fast ethernet ports that have 5 switches plugged in all on seperate VLANS
I have 1 cisco catalyst 2960.  the rest of the switches are old Linksys 48 ports
I have patched the cable modem that is upstairs down to the patchpanel near the cisco equipment.    I would like to somehow have my LAN traffic go out the cable modem for all users, and reserve the T1 for phone use only.  Is this possible with my current equipment.
I have tried to do policy based routing but I cannot assign the available ports to me an IP address.  I guess I'm not sure what I need to do next.. somebody said to assign the modem to a vlan but I'm not sure what he meant by that.
10 Replies 10
Seb Rupik
Hi Jason,
From what you have described this could be achived by creating a Layer2 VLAN on the 2800 router:
conf t
vlan 2
name lan_traffic
end
For each of the switch ports on the 2800 that are connected to switches which PC/ servers are connected to and the switch port which will go to the cable modem, you need to configre the same access VLAN on them:
conf t
int x/x
  swithport access vlan 2
  switchport mode access
  spanning-tree portfast
end
This will put all of your phone traffic on the default VLAN1 and all LAN traffic onto VLAN2.
However if your phones require some other network services which are provided by servers/ applicances on VLAN2 you will have to configure SVIs on VLANs so that traffic can be routed between the VLANs on the 2800. These SVIs will need IPs which reside on the subnets running on the respective VLAN they are connected to:
conf t
int vlan2
  ip address x.x.x.x x.x.x.x
end
Let me know if you need further clarification.
cheers,
Seb.
Okay,
makes sense but my config is a little more complex than that.  They have natting set up on there   maybe you could take a look at it (I've replaced all external IP addresses with x.x.x.x
crypto pki trustpoint TP-self-signed-xxxxxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxxx
revocation-check none
crypto pki certificate chain TP-self-signed-xxxxxx
certificate self-signed 01
(removed the encrypted jibberish)
quit
dot11 syslog
ip source-route
ip cef
ip dhcp database vlan2
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.30
ip dhcp excluded-address 10.0.1.1 10.0.1.30
ip dhcp excluded-address 10.0.0.201
ip dhcp excluded-address 10.0.2.240
ip dhcp excluded-address 10.0.3.1 10.0.3.30
ip dhcp excluded-address 10.0.4.1 10.0.4.30
ip dhcp excluded-address 192.168.10.1 192.168.10.30
ip dhcp pool VLAN4
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
dns-server x.x.x.x
ip dhcp pool VLAN6
network 10.0.4.0 255.255.255.0
default-router 10.0.4.1
dns-server x.x.x.x
ip dhcp pool VLAN8
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server x.x.x.x
ip dhcp pool _STATIC
host 10.0.0.31 255.255.255.0
ip ips notify SDEE
ip ips name sdm_ips_rule
no ipv6 cef
vpdn enable
vpdn-group 25
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 25
l2tp tunnel timeout no-session 15
voice-card 0
(removed authentication)
redundancy
crypto ctcp port 10000
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp key (statements_)
crypto isakmp client configuration group Vision
key xxxxx
pool SDM_POOL_1
acl 107
split-dns x.x.x.x1
split-dns x.x.x.x2
max-users 30
netmask 255.255.255.0
crypto isakmp profile sdm-ike-profile-1
match identity group Vision
client authentication list sdm_vpn_xauth_ml_2
isakmp authorization list sdm_vpn_group_ml_2
client configuration address respond
virtual-template 2
(crypto statements)
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA5
set isakmp-profile sdm-ike-profile-1
interface FastEthernet0/0
description WAN INTERFACE$FW_OUTSIDE$
ip address x.x.x.x 255.255.255.252
ip flow ingress
ip flow egress
ip nat outside
ip ips sdm_ips_rule in
ip virtual-reassembly in
duplex auto
speed auto
crypto map SDM_CMAP_1
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
description CORPORATE WIRELESS$FW_INSIDE$
encapsulation dot1Q 5
ip address 10.0.3.1 255.255.255.0
ip helper-address 10.0.0.10
ip nat inside
interface FastEthernet0/1.2
description GUEST WIRELESS$FW_INSIDE$
encapsulation dot1Q 6
ip address 10.0.4.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.3
description ANOTHER COMPANY$FW_INSIDE$
encapsulation dot1Q 8
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface FastEthernet0/0/0
interface FastEthernet0/0/1
switchport access vlan 2
interface FastEthernet0/0/2
switchport stacking-partner interface FastEthernet0/2/2
interface FastEthernet0/0/3
switchport access vlan 4
interface FastEthernet0/2/0
switchport access vlan 7
interface FastEthernet0/2/1
switchport access vlan 3
switchport stacking-partner interface FastEthernet0/0/2
interface FastEthernet0/2/3
(open interface)
interface Virtual-Template2 type tunnel
description $FW_INSIDE$
ip unnumbered FastEthernet0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Virtual-Template25
ip unnumbered Vlan2
peer default ip address pool PPTP
no keepalive
ppp encrypt mppe 128 required
ppp authentication ms-chap-v2
interface Vlan1
no ip address
interface Vlan2
description  CORPORATE$FW_INSIDE$
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Vlan3
description TRAINING ROOMS$FW_INSIDE$
ip address 10.0.1.1 255.255.255.0
ip nat inside
interface Vlan4
description VOIP$FW_INSIDE$
ip address 10.0.2.1 255.255.255.0
interface Vlan7
description DMZ$FW_OUTSIDE$
ip address x.x.x.x 255.255.255.224
ip access-group 102 in
ip local pool SDM_POOL_1 10.0.0.210 10.0.0.250
ip local pool PPTP 10.0.0.205 10.0.0.209
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip flow-export destination 10.0.0.125 2055
ip nat pool COMPANY x.x.x.x y.y.y.y netmask 255.255.255.252
ip nat inside source list 1 pool COMPANY overload
ip route 0.0.0.0 0.0.0.0 X.x.x.x
logging esm config
access-list 1 remark NATTING
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.3.0 0.0.0.255
access-list 1 permit 10.0.4.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.0.2.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 101 remark SDM_ACL Category=4
access-list 101 remark IPSec Rule
access-list 101 permit ip 10.0.0.0 0.0.0.255 192.168.0.0 0.0.3.255
access-list 102 remark RESTRICTED DMZ
access-list 102 permit tcp x.x.x.x 0.0.0.31 10.0.0.0 0.0.7.255 established
access-list 102 permit tcp any x.x.x.x 0.0.0.31 eq 3389
access-list 102 permit tcp any host x.x.x.x eq 8000
access-list 102 permit tcp any host x.x.x.x eq www
access-list 102 permit tcp any x.x.x.x 0.0.0.31 eq www
access-list 102 permit tcp any x.x.x.x 0.0.0.31 eq ftp
access-list 102 permit tcp any x.x.x.x 0.0.0.31 eq 115
access-list 102 permit tcp any x.x.x.x 0.0.0.31 eq 22
access-list 102 permit tcp any x.x.x.x 0.0.0.31 eq ftp-data
access-list 102 permit udp x.x.x.x 0.0.0.31 eq domain 10.0.0.0 0.0.7.255
access-list 102 permit ip x.x.x.x 0.0.0.31 any
access-list 102 deny ip x.x.x.x 0.0.0.31 10.0.0.0 0.0.7.255
access-list 103 remark SDM_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 10.0.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 104 remark SDM_ACL Category=4
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.0.0.0 0.0.0.255 192.168.0.0 0.0.3.255
access-list 105 remark SDM_ACL Category=4
access-list 105 remark IPSec Rule
access-list 105 permit ip 10.0.2.0 0.0.0.255 192.168.22.0 0.0.0.255
access-list 106 remark SDM_ACL Category=4
access-list 106 remark IPSec Rule
access-list 106 permit ip 10.0.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 107 remark SDM_ACL Category=4
access-list 107 permit ip 10.0.0.0 0.0.0.255 any
access-list 109 remark VPN to Chennai
access-list 109 remark SDM_ACL Category=4
access-list 109 remark Chennai Voice Traffic
access-list 109 permit ip 10.0.2.0 0.0.0.255 192.168.20.0 0.0.0.255
route-map SDM_RMAP_1 permit 1
match ip address 108
control-plane
banner motd  C
line con 0
password
line aux 0
line vty 0 4
transport input ssh
monitor session 1 source interface Fa0/0/1 , Fa0/0/3
monitor session 1 destination interface Fa0/0/0
scheduler allocate 20000 1000
end
Oh just to clarify that the VLANS that have the IP-HELPER statement are my inside LAN
so the subnets with 10.0.0.0 /24 10.0.3.0 /24 10.0.1.0 /24
the 10.0.2.0 /24 is the phone subnet.
Try the following:
access-list 2 10.0.0.1 255.255.255.0
access-list 2 10.0.1.1 255.255.255.0
route-map cable_modem permit 10
match ip address 2
set ip next-hop
interface vlan 2
  ip policy route-map cable_modem
interface vlan 3
interface vlan9
  desc cable_modem vlan
  ip address
int fa0/0/3
  desc to cable modem
  switchport access vlan 9
I assume your cable modem does NAT? Either way remove the 'ip nat inside' statements from interfaces vlan 2 and 3 .
Hope that helps.
cheers,
Seb.
Alright thanks, that makes perfect sense to me!!  I will test this after hours tonight and let you know how it works out.
Hi Jason,
On review, I think you need to add some NAT commands to my suggestion above.
First you need to NAT to VLAN 9 from 2 and 3:
interface vlan 2
  ip nat inside
interface vlan 3
  ip nat inside
ip nat inside source route-map cable_modem interface vlan 9 overload
You also need to tidy up the other NAT access-list:
no access-list 1 permit 10.0.0.0 0.0.0.255
no access-list 1 permit 10.0.1.0 0.0.0.255
Also, your existing NAT statement referes to a NAT pool 'COMPANY' which doesn't exist in the config. Should it refer to 'VISIONNAT'?
...and you have also left the external peer IP address visible in your config above.
cheers,
Seb.
IPOh alright I was wondering why my testing was still going out the t1 last night.   Also, I do harve a static IP available on the cable modem. would I need to create a second default route statement for that?
*thanks for the heads up on having some of those IP addresses showing still I thought I got them all.
okay I am trying this only on the 10.0.1.0 subnet for now since there is only one coputer in use there currently and it is not working
is there a need for a ip policy statement?  I think that is what may be missing also  I used the static addresses of the cable modem
Just to be sure I set a laptop on the cable modem and set the static IP address and it does work.
x.x.x.122 = usuable
x.x.x.121 = gateway
x.x.x.123 = Broadcast
vlan 9
ip address x.x.x.122 255.255.255.252
match ip address 10
set ip next-hop x.x.x.121
This issue is still not resolved, I am wondering if perhaps I need to remove my default route and add another policy based route statement for the rest of the vlans?
Your statement:
match ip address 10
Is not accurate for what we use with our local cable modem provider in similar situtation if next-hop x.x.x.121 is your cable modem.  The next-hop should be the gateway IP address provided by the cable provider.  I usually just do a tracert and find the next hop.  Make sure your ACL's are setup properly as well.
